Music Path
Previously known as hm22music.
- Apr 5, 2015
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Affirmative, that's the one!
When can we buy the new one?
And "how much is the fish"?
Sorry for german in the 1st screenshot ... but do you know why I do not get a higher rate than 96 kHz? Regardless which track, I do get just up to 96 kHz.
I tried it with firmware 5.3 and 5.3c - same result. I also used different USB ports (USB 2.0, 3.0 and 3.1). Windows driver is V 3.20.0.
The BL shows the MQA LED.
Anyone an idea?
Just to clarify, does this happen on MQA files and magenta LED is engaged?
The iFi micro iDSD Signature is available later this month from selected retailers, at an RRP of £649, (€699, US$649).
Yes. The micro iDSD BL shows magenta LED, but the ifi Control Panal just says 88,2 / 96 kHz but I know, that the track have 352 kHz (https://tidal.com/browse/album/59527094).
Maybe it is because the folding / MQA renderer?
Does it matter whether the led is magenta on the BL?
Thanks, Got it. So this means that it is the idsd that determines (LED) which quality it is playing and not Roon - I guess....Magenta LED is what indicates that what you're listening to is in fact MQA. If you see green LED on your BL and have MQA on your playlist, this means that what leaves your device is not clean MQA and some form of digital processing happens somewhere along the road.
Hi,
Is there a chance to use the BL with the optical input and the USB input at same time? I have a bought a B-stock unit. When i first tried it at home I had it connected from my soundcard (my main computer) trought the optical input and as well trought the usb (from my laptop).When i played music from the computer it worked. When i played music from my laptop it worked (i had to move the voulme pot for it to work). And could switch between the two (i always had to move the volume pot after the change). I volume matched the them and they sounded the same to me.
Since that first time Im not able to do the same. If the usb is connectet to the BL, the optical input is not working.
Maybe someone can help me how to do it again.
I cant switch between the two things. If the usb is used (with the laptop) I cant get the audio signal from the optical input. If i remove the usb cable, it works as it should.
