@dcguy73 thank you for taking time to share all those findings. In my case iCan Pro already has a decent black background but it may be still worth to check out this possible upgrade path. I would like iCan Pro to be more dynamic, but it seems that Niimbus maybe what I am looking for. Overall this is great amp with one single drawback: it makes you want moreWell, for one thing, you can roll your own power cable with it, so that opens up a lot of possibilities. And it gives the iCan Pro a blacker background that allows you to hear more details. If you want to take it to the next level, you could buy an iPower Elite and get the matching iFi SupaNova power cable that provides active power conditioning/surge protection. The two together make the background even quieter and allow you to not worry about power conditioning or surge protection and plug the iCan Pro directly into the wall.
ifI iCan Pro - Impressions & Discussion
- Thread starter grizzlybeast
Niimbus is two levels above Pro ICan.
Two questions:Niimbus is two levels above Pro ICan.
- Which amp is just a single level above Pro iCan?
- Which amp is a level above Niimbus?
1. Maybe V550?
2. Idk, best so far i heard is Niimbus.
dcguy73
Formerly known as dc_guy
Aren't we talking apples and oranges here?
The iCan Pro is a hybrid tube/solid-state amp. @vonBaron, all the "better" amps you've referenced are solid-state.
But still it have SS mode.
It depends if you are looking for particular sound signature / SQ only or are you looking for it with particular topology. In any case Pro iCan has a place on my desk due to its nature.Aren't we talking apples and oranges here?
Pro ICAN is very versatile amp, it have almost everything but if you want better SQ SS for similar price you can. Tube mode is very average unless you don't change tubes.
dcguy73
@vonBaron, I agree. @alekc, I own the Pathos Inpol Ear hybrid tube/solid-state amp and very much enjoy it. I think it is definitely a level or two above the iCan Pro. It is not nearly as versatile with settings (it does have an optional DAC built-in), but the sound quality is excellent.Pro ICAN is very versatile amp, it have almost everything but if you want better SQ SS for similar price you can. Tube mode is very average unless you don't change tubes.
But if you add better tubes and LPS to ICan you have IMO best AMP for under 2500$.
Gippy
- Dec 2, 2016
Amusing discussion about asking which amp is "better" than the Pro iCAN. Imagine buying this amp without the intention to use XBass/3D, because that's really what's going for it. If I wanted a "gain wire amp" I would've looked at other options. You can't compare this amp to anything else on the market other than iFi's other products with XBass/3D.
Honestly speaking I think that there is a lot more to both Pro iCan or any other decent amp than just 3d/xbass. I love xbass for some tracks; 3d works nicely on some particular recordings for me but Pro iCan made me to seek for SS amp that could be more dynamic, maybe with blacker background and wider sound stage.Amusing discussion about asking which amp is "better" than the Pro iCAN. Imagine buying this amp without the intention to use XBass/3D, because that's really what's going for it. If I wanted a "gain wire amp" I would've looked at other options. You can't compare this amp to anything else on the market other than iFi's other products with XBass/3D.
tamleo
- Jul 13, 2010
do the pro ican have an intimate soundstage? TksHonestly speaking I think that there is a lot more to both Pro iCan or any other decent amp than just 3d/xbass. I love xbass for some tracks; 3d works nicely on some particular recordings for me but Pro iCan made me to seek for SS amp that could be more dynamic, maybe with blacker background and wider sound stage.
I'm really poor at all those naming conventions especially since those terms means usually something different to different people. I'd say there are amps with better soundstage but those I've heard were more expensive than iCan. It has wider stage than iCan SE, but I like both and I'm using both with different setups.do the pro ican have an intimate soundstage? Tks
Nicolas Yance
Yes the Pro iCan is more intimate than other amps but I manage to make it wider by swapping the tubes like others recommended before.
Total: 9 (members: 0, guests: 9)
