mukihr
- Oct 15, 2007
o.k.....
so, the story with my Zen Stream ended in a way that i spoke with a supplier and he told me to return the unit and that he will send the new one....
he did... and also put a Cambridge audio coffee/tea/cold watter bottle in the package too (nice!!)
so,... the new unit - started as it should, connected as it should... spdif i had to connect from local settings like yogurtlidlicker told us to try - which is o.k....
so far it is working on either spdif or usb... no problem... did not loose connection so far... everything great...
BUT! (you knew it was comming - right ?)
old one did sound a bit better (that little that i was able to listen to it while it was stil working)
crazy how it sounds but it did sound better....
so, right now i have two options to listen to tidal - using my android tv to chromecast to it and via optical cable into my m2tech dac....
second option is zen stream (turned on tidal mode)....
had listened the first one it was better then my tv option... this second unit is sort of equal to my tv - some things are better some things are worse then my tv option....
so, i have a couple of questions - my power supply is a regular one supplied by iFi... 12VDC/1A black block of something inside....
how much a good linear power supply would make sound better - how much better - could anyone tell me that??....
also how turning from 12VDC to close to 15VDC will change sound? in what way...?
thank you guys....
thank you guys....
