iFi Audio Zen Dac 3... Plug In, World Out!
Sep 12, 2024 at 10:01 AM Post #316 of 395
Not possible. The DAC's volume control is a physical volume control that only works for its own outputs, it's not possible for it to control Windows' volume that way.
The best way to control Windows' volume control is to use a keyboard that has that as a feature. For example, I have a Razer keyboard that can control playback and volume control in Windows.
That's not what I mean. When using Zen DAC 3 the volume control on Keyboard, or on the Windows just doesn't work. no matter what volume I adjust it to. it look like Zen DAC 3 just bypass it.
Sep 12, 2024 at 10:13 AM Post #317 of 395
That's not what I mean. When using Zen DAC 3 the volume control on Keyboard, or on the Windows just doesn't work. no matter what volume I adjust it to it look like Zen DAC 3 just bypass it.
Yes because you are using USB output to your Zen Dac as your output so you only can control the volume from the knob. You have to choose other Sound Output
Sep 12, 2024 at 2:28 PM Post #320 of 395
Let me clarify this one because I can understand what he's saying.
* IFI's audio output is NOT bit-perfect on Windows
* Windows volume control does not work when Zen DAC3 is connected. This works with all other DACs I have and they are all USB-C. Whether using default driver or IFI's USB driver, it's the same.
* Volume control adjustment works in apps - Browser (Youtube), Apple Music, Qobuz, Spotify etc. It's only the Windows Volume control that is locked which is indeed weird.
I don't fully understand this but I'm guessing the Zen DAC 3 locks the digital volume control in Windows to avoid any issues.
Sep 12, 2024 at 7:59 PM Post #321 of 395
Yes, the issue is just like what you describe.
Sep 12, 2024 at 8:13 PM Post #322 of 395
ASIO routes audio straight to to your audio output. It bypasses Windows, so Windows volume control is unrelated to it.
The same thing if you are using TIDAL
Sep 12, 2024 at 9:58 PM Post #326 of 395
Sep 13, 2024 at 3:41 AM Post #327 of 395
You still don’t understand. This has nothing to do with ASIO or bit-perfect output. You can still adjust volume within apps on Windows. Try to change volume on YouTube, it works fine.
Sep 13, 2024 at 3:48 AM Post #328 of 395
Anyways found the answer in the above Reddit post. Newer IFI DACs do not implement Software volume control. This is just a limitation of the Zen DAC 3 and other IFI DACs. Let’s move on :)
