jsmiller58
I will have to back up this post, and the observations of @drey101... I have two xDSD units, and the DM6. The DM6 has a very low, but noticeable hiss when plugged into either of my units on 3.5mm SE (have not checked balanced). Volume independent until it gets to RED, when the hiss gets very loud. Easiest way to “hear” the hiss at low volumes is to simply unplug the headphones - from hiss to nothing.Based on the official data (110dB/1mW & 18 Ohm) this IEM translates into 127dB/1V, which means a small amount of background hiss may be audible. As IEM/headphone sensitivity varies greatly comparing background noise is only valid using the same IEM.
If items the customer mentions as "not having hiss" are compared under the exact same background noise conditions, with the same IEM and with equivalent gain settings, it is likely they will have similar levels of hiss with the same IEM.
Naturally, the solution is to add iEMatch or Earbuddy.
However, I love my xDSD(s) so, a little hiss flying under the level of the music is no big deal. But no denying it, this is really there.
