iFi audio xDSD- The Official Thread
post-14556286
Post #991 of 1,982
Bansaku
Edmonton, AB
Edmonton, AB
Age
41
Nothing will get damaged, but the benefit (if any at all) would be slight and questionable.
Ok cool. Just wanted to know before my xDSD arrives (hopefully soon, it's been 3 weeks and the wait is killing me). I wasn't getting any crazy ideas or anything, rather me being lazy and not wanting to solder on a new plug to the cable I made as the 8-braid I did is perfect and I fear I might not get the new one as nice looking. First World problems... :laughing:
post-14557741
Post #993 of 1,982
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
post-14557996
Post #994 of 1,982
SeinUndZeit
Milan
Milan
https://www.head-fi.org/threads/ifi-audio-xdsd-the-official-thread.873787/page-66#post-14553613
Desktop mode should activate itself.
You may want to try to completely disconnect the xDSD and turn it on and then off and make the power connection when turned off.
When turned off, the unit does remain powered and may have a small amount of temperature rise, as the MCU and battery management are still operating. Desktop mode simply adjusts the target voltage and charge current for "equal to storage life" battery conditions.
Thank you for the answer @iFi audio , I tried but it still seems to be to be constantly charging and reaching 100%. Even when turned off it is pretty warm most of the time, but not always, no idea why. When in desktop mode, the light near the micro USB should be green?
One last thing: when attached to the power supply and turned off the frontal wheel turns reddish, is it normal? What is the meaning of that?
Thank you again!
post-14558810
Post #995 of 1,982
superuser1
Sapta Sindhu
Sapta Sindhu
post-14558816
Post #996 of 1,982
sbtourist
London, UK
London, UK
We're working on it and don't have specific date yet.
Thanks, your website says October 2018 so that's why I was asking. Hope it will not be too much waiting, the Windows version has been around for a while already.
Reactions: RockStar2005
post-14560386
Post #997 of 1,982
Youghin
apologise for such noob question, since XDSD could support 3.5mm balanced, could my 2.5mm cable male change to 3.5mm balanced male? since the cable is meant for balanced male
post-14560396
Post #998 of 1,982
rbalcom
Lake Jackson, TX
Lake Jackson, TX
post-14560488
Post #1,000 of 1,982
rbalcom
Lake Jackson, TX
Lake Jackson, TX
I found a 3.5mm balanced male, pentaconn 3.5mm. around US60. but need to seek for help to rewire
The adapter is the easiest way to use a 2.5mm balanced plug. If you want to change to a 3.5mm TRRS plug, the 2.5mm is wired:
Tip Right-
Ring Right+
Ring Left+
Sleeve Left-
and the 3.5mm TRRS plug needs to be wired:
Tip Left+
Ring Right+
Ring Left-
Sleeve Right-
Good luck.
Reactions: Youghin
post-14561514
Post #1,001 of 1,982
RockStar2005
Chicago Suburbs
Chicago Suburbs
Hi iFi and all,
I was just skimming this article, which I think you'll all be pleased to look at, and I have a question to ask.
It says for the xDSD: "It supports aptX on Android and AAC on iOS for the best sound quality". PLEASE tell me that if I want to, I STILL have the option to use AAC on my Android phone instead of only aptX!! I believe AAC to be the superior codec of the two, so I'm hoping this is not the case.
Thank you.
post-14565255
Post #1,002 of 1,982
4Real
Hi iFi and all,
Thank you.
It has nothing to do with the xdsd, your device sets the codec used over bluetooth, if your running android Oreo or above you can set which codec it uses from within developer mode.
post-14565399
Post #1,003 of 1,982
RockStar2005
Chicago Suburbs
Chicago Suburbs
Ok. As long as you're SURE I can use AAC on Android, it's all good! I've already read reviews that stated the xDSD sounds better with AAC than most cheaper devices do with LDAC, which is VERY impressive to know! :L3000:
post-14569567
Post #1,004 of 1,982
bonakid
Hey guys! Has anybody tried using the xDSD with their Smart TVs or laptops while watching? I would like to know if there some lags / delays with respect to the audio and video. Thanks!
post-14569696
Post #1,005 of 1,982
seaharp1
I just bluetooth connected to my 2011 mbp...watching youtube vid podcast...no lag.
My Panasonic tv doesn't have bluetooth.
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
