dcime
Without too much detail...
Android OS in general runs all audio through the Android audio stack, resampling all audio to 16/48. There are only a few devices that bypass this as they are MQA certified and the Tidal Masters audio runs through the DAC untouched. These are the LG V30 and higher devices and perhaps the g7 and g8. This resampling is an issue in the OS itself. UAPP is an app that takes control and bypasses the native Android sample rate conversion, allowing the first unfold by the UAPP app. Unfortunately, external apps running Tidal are streaming only.Without too much detail...
Can you please explain this in Android 9 OTG setup with say a Note 9 device?
Thank you again
How does MQA work within the TIDAL app?
The TIDAL app contains the MQA core decoder and performs the first unfold of an MQA file. Huh?
What happens if I connect my Android or iOS device to an external DAC?
(xDSD)
If you connect an MQA-enabled DAC, (containing the MQA renderer), you will get the authentication light and the optimal audio quality.
Magenta?
And why should I be using UAPP app?
Sorry I went into full detail. I've been running Android since it's inception in 2007. I use a used iPhone 7 as a digital transport for music only for apps such as Tidal and QobuzWithout too much detail...
Thank you again
(xDSD)
Magenta?
Thank you. That makes perfect sense to me. I guess iOS has a couple advantages over Android in the bit perfect MQA world. Since I use a Note 9, I have less choices. In fact seems like UAPP is only way to go.Sorry I went into full detail. I've been running Android since it's inception in 2007. I use a used iPhone 7 as a digital transport for music only for apps such as Tidal and Qobuz
Will an iPod touch work as well or the same using WIFI?Sorry I went into full detail. I've been running Android since it's inception in 2007. I use a used iPhone 7 as a digital transport for music only for apps such as Tidal and Qobuz
Thanks, so iPad too, yes with wifi only ?Absolutely! Can confirm 100%!
iPod touch will give you bit-perfect audio to external DAC using Tidal for all audioWill an iPod touch work as well or the same using WIFI?
iOS devices can and will play Tidal bit-perfect to external DAC streaming or using storage. I have a used 256bg iPhone 7 loaded with Tidal music I use with xDSD and a chord MojoWill an iPod touch work as well or the same using WIFI?
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I listen to xDSD in Bluetooth half the time, and it's awesome. The primary I go wired is because I use Tidal hifi, and like activating the MQA capability of the DAC, but it is an awesome DAC/amp in either modeHey all,
Does anyone here have the xDSD and the Fiio Q5S? I am planning on getting a DAC/AMP exclusively for pairing with my Iphone 11, from what I have read the xDSD seems to have better bluetooth/sound and I travel a lot so I'm going to be using it 70% of the time in bluetooth mode. I've read through there quite a bit, but most of the comments that discussed bluetooth connections just said 'its worse', is the bluetooth connection so bad that it's just completely inadequate or is bt good enough quality to listen to some harder to drive IEMs like the Legend X?
I do not have Fiio Q5S but read the following article first how iFi treats Bluetooth. For me their Bluetooth implementation is excellent enough for the portable and casual use.Hey all,
