Very nice! I also hooked an AHB2 to up to my iESL that iFi USA sent out and I just received.
This setup (DAC3-> HPA4-> ifi iESL -> AHB2) drives my Sennheiser HD800S's really really well. Like the best I've heard them! Unbelievable bass with this combo. I didn't turn it up all the way, but seems I get more power than with the Benchmark HPA4's headphone amp (which is already a great headphone amp). I have turned up the HPA4's headphone amp all the way before, so I'm getting a lot more headroom with this setup, although I didn't measure to verify.
Question for
@iFi audio and others:
However, I'm not getting the same loudness and bass quality when I tried my new Audeze CRBN's that just came (also months after ordering). I don't own any electrostatic amps and the lack of jaw dropping bass may very well be the electrostatic driver. That said if I try to get the same loudness by raising the volume on my HPA4 above 0dB (using it as a preamp not a headphone amp), a clip light comes on on the AHB2 at peaks when driving the CRBN's with the iESL. It seems I may actually need two AHB2's to drive some electrostatic headphones like the HPA4?!? I do have the ifi iESL on the lowest impedance setting (16 ohms), same setting I use when I have the HD800s' hooked up. Would be great if I could get the CRBN's as loud as the HD800's with this setup so I never have to increase the HPA4 past 0dB and can avoid clipping. Sounds to me like there's a 8-10dB volume difference between these headphones thru the iESL with the HPA4 set to 0dB. Could be due to the differences in efficiency between the CRBN's and the HD800's, something to with the the input impedance of the iFi iESL, etc... Not sure, but figured someone has ran into this here, so thought I'd ask.
