- Mar 20, 2013
I would imagine so, as the audio signal passes through the SS or tubes on its way to any output, either the HP jack or RCA and XLR.
Hi,
To answer this and the previous question posed.
For the iDSD Pro we really went back to the drawing board after the first version. As a result its basic topology is very purist; which literally means just a passive lowpass filter, Volume Control and an Output Amplifier that could drive Headphones or Line Outputs with equal quality. This ultra simple signal path is one of the reasons that allowed the iDSD nano to offer such good sound quality on such modest budget. Its giant slayer status is largely attributed to this approach and we are adopting the same for the Pro iDSD.
Of course, for the iDSD Pro we have improved the quality and performance of these basic blocks massively. And we mean massively.
The passive low-pass filter incorporates inductors to form a LCRC filter with better filtering of unwanted digital noise while offering a wider audio bandwidth free of analogue phase-shift.
The Volume control is no longer a Chip, instead a balanced Alps Potentiometer (16mm Alps Black) is used. There is more to this Volume control which will be revealed at a later time.
The Output Amplifier is our new all discrete “Pro-Stage” which does away not only with Op-Amp Chips themselves but even with traditional Op-Amp like structures implemented discretely (e.g. like all these “discrete Op-Amp replacements”. It should be quite unique. Instead the circuitry owes much to the discrete designs of both Neumann and TAB-Telefunken for the West-German radio & TV studio equipment and those of the RFZ in former East-Germany, either of which justly enjoy 'legendary' status in the Pro audio world. Integrating the option to switch the crucial and sound quality determining first gain stage between tube and a j-fet gives additional control over the sound quality.
The actual output stage of this circuit is a new Class A design with enough current delivery and available voltage (14V peak & 700mA peak) to drive any modern headphone and equally capable of driving even the most difficult line inputs (e.g. 600 Ohm matched transformer coupled Pro-Audio).
As such there is no Headphone Amplifier that could be removed, if a Headphone is connected the line outputs are disconnected and muted and the same single stage now drives the Headphones. Equally, the choice between Transistor or Tube for the key amplifying stage applies equally to line outputs and headphones.
We hope this clarifies this part of the design somewhat. As said,it is a ground-up new design - it is unlikely to arrive before November. For the moment, this is as much as we can say - we are trying to walk the line between not getting you all too excited, yet answer some of the questions posed without giving too much away. Not easy.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
