Hi All.
Thank Crunchie it is Friday.
There are the latest specs, they are subject to change and we may throw in one or two surprises (cos we know you like surprises).
Have confirmed iwth the R&D people that this is what we can divulge.
iCAN Pro
Here you go:
Key features are:
- Balanced Output options on 3-Pin & 4-Pin XLR plus 6.3mm Jack on front panel.
- Unbalanced outputs on 6.3mm Jack (direct) and two 3.5mm Jacks with built-in fixed iEMatch attenuation on front panel to drive IEMs etc. (same attenuation as in iDSD micro).
- Balanced XLR & RCA outputs on back can carry Headphone out signal (for use as preamp or with Electrostatic Energiser) or loop through signal from inputs (for use with external pre-amp).
- 1 pair of XLR Inputs and three pairs of RCA Inputs.
- 20V maximum output, > 600mW into 600 Ohm headphones, appx 16,000mW maximum into 16 Ohm and appx. 6,000 mW continuous output into 16Ohm.
- Three levels of gain selectable from Front Panel.
- Balanced ALPS Volume control with remote control.
- 3D Holographic® for Headphones and XBass® (each adjustable in 3-Levels + Off).
- Class A operation for all stages up to 240mW/600 Ohm, circuitry derived from professional tube-based studio equipment, implemented in a hybrid design mixing J-Fets, Bipolar transistors and Mosfets (as in Micro iCAN).
- Full Dual-Mono design including internal power supplies, supplied with 15V/4A Ultra Low Noise PSU (Generation 2 design as also the updated PSU for Micro).
- Optional Electrostatic Headphone Energiser in separate Box will be introduced, 1,700V Peak-Peak maximum output, Bias selectable for Stax HiFi/Pro, Sennheiser and others, Output Levels selectable, 3 * Stax Pro & HiFi Sockets fitted.
Balanced Headphone Amplifier
PowerSource:
| External DC 15V/4A
Inputs (Back):
| 1 x XLR True Balanced Stereo
| 3 x RCA Stereo
Output Front):
| 4-Pin XLR Headphone Balanced
| Dual 3-Pin XLR Headphone Balanced
| 6.3mm Headphone x2, single ended or balanced
| 6.3mm to 3.5mm adapter included
| 3.5mm iEMatch attenuated x 2
Output (back):
| XLR selectable Loop or HP Out
| RCA selectable Loop or HP Out
Volume Control:
| Motorised ALPS 6-Way potentiometer in unique extended range series/shunt operation
Analogue Processing:
| X-Bass, +3dB at 80Hz, 160Hz, 320Hz
| 3D Sound. 30/45/60 Degrees virtual Speaker angle
Gain:
| 0dB, 12dB and 24dB user-selectable
Signal to Noise Ratio:
| >117dB(A)
Total Harmonic Distortion (THD):
| <0.003%
Frequency Response:
| 0.5Hz to 500KHz(-3dB)
Output Power (16R cont):
| > 6,000mW
Output Voltage (600R):
| >20V (Balanced); > 10V (single ended)
Size:
| 220mm x 62mm X 190mm (W X H X D including feet and connectors)
