Assationater
You can always return if you cant hear a difference.You can save yourself more by not buying any additional power supply.
In 99% of use cases, the difference in performance if any is negligible.
Nice!!!Zen CAN 3 in the house with its siblings
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Thanks so much for the thoughts in the review, very much appreciated!My review of the ZEN Can 3 is here:
https://www.head-fi.org/showcase/ifi-zen-can-3-headphone-amplifier.27740/
You could just power the Zen Can and let the Zen DAC be powered from its USB source if that's feasible for your use case.Is there a way to power the zen can and zen DAC from a single outlet ?
My source is mostly my phone so I want it to be powered with another sourceYou could just power the Zen Can and let the Zen DAC be powered from its USB source if that's feasible for your use case.
Cheers!!
I see, in that case, yes unfortunately you would need to power both.My source is mostly my phone so I want it to be powered with another source
No way to chain the DAC/Can ?I see, in that case, yes unfortunately you would need to power both.
Cheers!!
Not power-wise no, perhaps a single power supply with 2 separate 5V outputs may work for you.No way to chain the DAC/Can ?
