I received my iTube and it's currently settling in. I took a quick listen after about ~4 hours of warmup; first impression is that the Tube+ switch modes (SET, "classic", P-P) differences are somewhat subtle, at least on the single piece of music I listened to (a violin concerto). My first take is that the classic mode reminds me of the voicing of the Tube mode on the iCAN Pro; open, detailed, with a fairly wide soundstage, with nice, full timbre and good dynamics. SET reminded me a little of Tube+, where the soundstage narrows somewhat but also deepens, timbres richen but dynamics and detail are lessened. Push-Pull sounded very harmonically rich and what I would call classically "tubey" from a hi-fi perspective, reminding me a little of my old Audio Research SP16/VS55 combo of some years ago. I need to revisit the P-P mode as I really didn't spend much time in it.
Compared to the sound without the iTube in the chain (iDAC2 > iCAN Pro Solid State mode), when putting the iTube in the chain between the iDAC2 and iCAN Pro I heard a similar slight but meaningful fleshing out of instrument tones and weight, as well as slightly less outline definition to the images but a better sense of 3-dimensionality. This is very similar to the iCAN Pro SS vs Tube mode, where I hear similar differences. I did not seriously compare vs the iCAN Pro's Tube or Tube+ mode, though, as I don't have 2 perfectly matching interconnects (except the ifi freebies, which are OK but I find somewhat slow and veiled). I'll try to rectify that situation and revisit later, as I'd like to flesh out the "reminds me a little" statements above.
My first thought, though, was that the "classic" mode is really well implemented, with no real negatives detected, at least in the initial quick listen. I hope that holds out, as it should make the iTube2>iCAN SE into a nice little facsimile, at least in some small way, of the iCAN Pro itself.
My impressions may change radically as the unit burns in, and as I listen to a wider variety of music. This was literally less than one hour of listening, so I reserve the right to flipflop
I really need to let the iTube (and the new iCAN SE I got to go along with it) burn in for a bit before "real" listening commences.
In any case, to pass the time while that occurs...
@iFi audio , I'm curious as to what is happening when I flip the switch on the adjustable Tube+ feature. I initially thought this would only be a change to the global feedback amount, similar to the Tube to Tube+ change on the iCAN Pro. My iTube2 is not at all settled in, and therefore my initial findings may be invalid, but what I heard suggested there may be more going on here than a feedback change. Curious to know what that switch is really doing
