Dixter
- Dec 21, 2011
wonder why they didn't use the 1795.... I think I know the answer... cause thats all they know...
I already have similar setup but with M15 and signature. I also use velcro patches, so I can change daps, phones with my various amps. This stack sounds better and is more powerful than most desktop systems.Well this is my plan... hope it works out... I put in an order for the Diablo and one of the OTC cables... I'm going to mount the fiio M11Pro SS to the Diablo (bands,pad).. if all goes well then I should have a very powerful stack, it will have full MQA with the M11Pro SS as the transport for Tidal... the output of the Diablo will be the primary power for over the head phones(true balanced), the output of the M11Pro SS will be for balanced IEMs and for the wireless I'm going to be using the fiio UTWS3 mated to FH7 or my Custom Arts... and the whole package will be housed in the Van Nuys Astell case https://audio46.com/products/astell-kern-protective-carrying-case-by-van-nuys? variant=29128198881395&utm_medium=cpc&utm_source=google&utm_campaign=Google%20Shopping&_vsrefdom=adwords&gclid=CjwKCAiA6aSABhApEiwA6Cbm_6SoySbjpfcIBoBkHUSt-Eu9YBTWZ3yQjgb_UAhryvKocxqwXsJFVhoC-z4QAvD_BwE
To recap the capabilities :
4.4mm true balanced output for over the head phones (Diablo)
6.3mm Single Ended (Diablo)
2.5 true balanced output for IEMs (M11Pro SS)
4.4 true balanced output for IEMs (M11Pro SS)
3.5mm single ended (M11Pro SS)
Wireless output for OHP and IEMs, various HQ codecs (M11Pro SS)
Full MQA decode with streaming Tidal
Full MQA decode with onboard MQA albums (M11Pro SS)
All streaming platforms, Tidal,Radio Paradise,SiriusXM,Amazon Music and others
HQ transport platforms, Fiio Music, HF Player, USB Audio Player and others
1 TB of on board HQ music formats, including FLAC, DSD, MQA, and others
In a pretty small package too...
Will the M15 output bit perfect with an external DAC? Or will that kick in the Android SRC? Pretty sure you’d need UAPP to output to the external DAC in bit perfect and to do the first MQA unfold to pass to external DAC. That’s how I had to do it with the HiBy R5. Downside there is no downloads from Qobuz or Tidal when using UAPP, just streaming.Well this is my plan... hope it works out... I put in an order for the Diablo and one of the OTC cables... I'm going to mount the fiio M11Pro SS to the Diablo (bands,pad).. if all goes well then I should have a very powerful stack, it will have full MQA with the M11Pro SS as the transport for Tidal... the output of the Diablo will be the primary power for over the head phones(true balanced), the output of the M11Pro SS will be for balanced IEMs and for the wireless I'm going to be using the fiio UTWS3 mated to FH7 or my Custom Arts... and the whole package will be housed in the Van Nuys Astell case https://audio46.com/products/astell-kern-protective-carrying-case-by-van-nuys? variant=29128198881395&utm_medium=cpc&utm_source=google&utm_campaign=Google%20Shopping&_vsrefdom=adwords&gclid=CjwKCAiA6aSABhApEiwA6Cbm_6SoySbjpfcIBoBkHUSt-Eu9YBTWZ3yQjgb_UAhryvKocxqwXsJFVhoC-z4QAvD_BwE
It does output MQA, the signature even gives me the purple lightWill the M15 output bit perfect with an external DAC? Or will that kick in the Android SRC? Pretty sure you’d need UAPP to output to the external DAC in bit perfect and to do the first MQA unfold to pass to external DAC. That’s how I had to do it with the HiBy R5. Downside there is no downloads from Qobuz or Tidal when using UAPP, just streaming.
Hello
Since I have my ifi micro idsd signature, I listen to microphones when I turn the volume up or down.
Depending on the song, that noise is more or less noticeable.
A friend has the original ifi micro idsd, the silver one, and it does the exact same thing to him.
He told me what happens in almost all ifi.
It's something that I don't give much importance to since I'm not changing the volume frequently, but I don't like it either.
Is it a general problem or only occurs in some units?
Cheers
So I've read through this thread entirely and realized that I haven't added to it.
Here's a comparison post I made while I struggled deciding between the Signature and Diablo.
https://www.head-fi.org/threads/ifi...e-reference-done-our-way.951615/post-16119721
And this is how I'll Schlep it around once that becomes a thing again
It's a Peak Design Tech pouch. Protective enough, light and lots of room for other stuff including adapters, battery backup etc.
Really enjoying the Signature now that I have it back!!
Chibs
Thanks Sebastein,Peak Design is awesome! They make what I use as my main camera strap for my t7i.
Glad you got your Signature and are having a wonderful time with it?
I use just Eco (my IEM are 112 dba). They need more power, I face with a sound quality drop with any of IEMatch mode.Hi all, I just bought an iDSD Signature and have been really enjoying it so far.
For those with sensitive IEMs, do you prefer to have it on Normal or Eco power mode (with IEMatch set to Ultra)? I see claims that the soundstage is better in Normal mode even for IEMs, is it how it should be used unless you are on the road and need to minimise battery drain?
Thanks for any tips in advance!
