Hey /‘hello’ __________________this post only talks about firmware flashing______________
I am not the ‘right person’ to handle your full enquiry; in part out of laziness, but mostly due to being, potentially, unfamiliar with steps needed/required=> I do not wish to make anything more confusing or difficult.
-=Just adding$0.02 worth of ‘commentary’.. (if ye wish)=-
The two pictures you have sent (being vastly different file sizes, one file size being quite inappropriate for the info in contains (5megabytes for an error message?)), might reveal how comfortable you are/knowledge of ‘all things computing’.
It is true a lot of the world like easy interactive devices (apple), and outside of PC professionals, most Windows users are just happy being able to turn the computer on and off again (and having it do either of THOSE tasks reliably).
As a technician /support agent to the PC platform - I would suggest we need to ‘get back to basics here’.
It seems that the software isn’t installed, and that ‘figuring out how to install the software’ is the present hiccup.
Now, firstly, relax.
Firmwares aren’t worth stressing over unless your device isn’t working and a firmware is the only thing that will fix it (VERY UNUSUAL SITUATION)
Firmwares that add features (eg gaming console support) might be of interest,.. ‘perhaps casual/offhand’.. so lets be ‘casual’.
I use a different product (also by iFi)
I do not use that product with a Windows PC, and so when it came time to do firmware flashing, I was coming at this task from a different angle.
At the moment I am assuming that the control panel applet offers more functionality, but (from a hazy memory) I also recall that the ‘flash file’ (the executable/‘program’ that changes/‘flashes’ different firmwares) was installed in the audio driver location...
If this is the case- installing a new firmware involves a few steps..
Download DRIVER package AND a new FIRMWARE (so TWO DOWNLOADS MINIMUM)
Install DRIVERS
Find Driver install directory, and find the flashing utility. (Run the flash utility)
When the flash utility is running it will want to be pointed at a firmware that you have downloaded (and wish to install)..; (so you may need to preempt this need and download and unpack a firmware/bios file into a directory that is easy to find).
As a ‘good rule for housekeeping’ (a Microsoft Windows PC), whilst everything ‘WANTS TO HAPPEN ON THE DESKTOP’, try forcing installations and (
more importantly) ‘unpacking’ compressed files to a location that
ISN’T the desktop.
Some software and installers can have issues with the desktop location as it is stored as part of an ‘individual users account’, where as Folders off the primary drives’ root directory (eg C:\Progs\Sound\iFi ) are handled in a way is tried and true.
The biggest issue for some installations NOT WORKING, is trying to install programs from compressed files. Whilst it may work 9/10 times, or even 99/100 times when installing software from a compressed folder, SOME SOFTWARE likes being uncompressed first, before installation. (ie unpack the installer, then open the ‘unpacked installer’, and THEN run the SETUP.EXE)
I vaguely recall a few more niggles than typical when trying to firmware flash the iFi parts, and relegate the process to one of the worse flashing modern experiences a user could have. (Flashing most other products is easier than the way iFi have it at the moment)
So steps to make the method easy was making a folder on the main drive called “iFi” (so C:\iFi) into C:\iFi was the install of the iFi software (that included the flashing program I needed), and then in a subfolder to C:\iFi I created a firmware folder.. (eg C:\iFi\firmware).
Now depending on how much you want to run a few firmwares, if they all have similar sounding names or names that mean nothing to you,.. then I encourage you to make folders in the firmware directory (such as GTO), that allow you to place the firmwares you download into folder that you A)know where it is, B)know what it contains
That little bit of housekeeping makes flashing firmwares super easy, as when we run the flash executable, and go to ‘choose the firmware’, we will find our downloaded firmwares EASILY and WITH CONFIDENCE as to what the outcome will be with any given firmware flashed.
Generally I only firmware flash from a (battery powered) laptop.
The firmware process was a time sink for the first instance (learning a new skill) and then SUPER EASY TO PERFORM (you will wish you had done so
sooner)
I found each step of the process from finding the (FIRMWARE) files to finding the actual flash program all small bumps in the road, and following a setup guide (to get the flash software that allowed me to change the firmwares) made the road smoother.
Of course iFi COULD do a lot to improve the process and take out a few of the corners that take us in the wrong direction, however briefly, on our way through this ‘nightmare’.
It is only scary, the first time, due to being unfamiliar. Once done it may never need doing again, and if it does, the process takes around a minute to start ; with most time lost to the seconds it takes to actually write the tiny file to the device.
As YoGabbaGabba famously once said “Try It, You may like it”. (the forty times he said it right after that first time are the ones we can never delete from our brains)
TL: DR ______Firmware flashing safe practice and good housekeeping________
probably right to skip this post; I am sure iFi would have an ‘easy step by step’ firmware guide (with troubleshooting) in a handy PDF download.
