Soundizer
- Dec 29, 2015
What headphones you use?I had that channel imbalance issue on iDSD Micro BL, on iDSD Signature but it is almost non-exsitent on the Diablo with all my headphones.
Well, I had the same fleet of headphones with iDSD Signature and the imbalance issue was there.It comes down to headphones sensitivity and how gain is designed.
Snorry NM-1 (40 ohm, 93 dB), Snorry SI-1 mk2 (40 ohm, 100 dB), Aeon C Flow ( 14 ohm, 92 dB)What headphones you use?
Is it not in Diablo?
I believe it's a clone of the alps alpine rk097 potmeter, as it looks the part but bears no alps alpine markings...No, the fact that there are reports of channel imbalance is proof Diablo is a pot.
If it had xDSD's design, there would be no reports ever again of channel imbalance.
Also mentioned on Diablo FAQ page anyway.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I mentioned xDSD uses a digitally controlled analogue volume control (perfect channel balance) and keep forgetting Neo iDSD has it too.
https://ifi-audio.com/wp-content/uploads/2020/11/iFi_NEOiDSD_TechLowdown_01.pdf
Also see:
https://ifi-audio.com/faqs/its-rotary-knob-would-suggest-an-analogue-potentiometer/
This means perfect channel balance even at lowest knob position, all the way to max volume.
So if you're using really sensitive cans, being 'limited' to small range is a non issue in terms of channel imbalance.
Anyway, maybe a future portable iDSD (like many hoped for years)
Neo iDSD is great but I'm hoping for a Black Label or Diablo Red version , for my desktop
Those chips fix the channel balance but degrade sound quality, I guess they wanted the best sound quality.Makes you wonder why they decided not to do this with their flagship dac/amp, being aware of the channel imbalance issue...
how do they degrade sound quality though? from my limited understanding the volume pot controls the voltage input into the amplifier section, in doing so the volume changes.Those chips fix the channel balance but degrade sound quality, I guess they wanted the best sound quality.
Everything in the signal path degrades quality.Those chips fix the channel balance but degrade sound quality, I guess they wanted the best sound quality.
They've obviously thought about it for some other products and implemented.
Lucky you! Mine needs to go beyond 11 o'clock to get rid of channel imbalance.My unit is great with minimal channel imbalance. With the unit on, its just below 9 o'clock. I get volume at 10 o'clock, imbalance is gone barely past 10 o'clock. Mainly listen to at 12 or just barely behind it. Switch is in Normal mode 4.4 output, focal elegia ( so easy to drive ) just my personal experience, I have no issue with imbalance personally. I like the volume pot a lot, you just need to be very delicate and precise when setting your level imo
Would you conclude this is a good implementation? I don't feel great cause I don't listen at high spl and I didn't get a golden copy. Please seriously consider digital volume control. If you need an example of that implementation, take a look at cayin c9. That thing has a analog nob with smooth digital volume control and no channel imbalance.Suffice it to say, every volume control type has some drawbacks, and implementations is also important.
