It has taken so long to get it back, I kinda lost all interest to write anything about it anymore.Will there be a review this time?
iFi audio GO pod + IEMs = brilliant wireless sound on the GO!
- Thread starter iFi audio
gryffe
- Jun 11, 2014
gryffe
- Jun 11, 2014
Double post
C4PPY
- Mar 7, 2015
Does the Go Pod support LHDC at 24/192? Just saw this new transmitter which looks solid. https://www.kickstarter.com/project...res-audio-bluetooth-transmitter?ref=discovery
And it's out -
V1.52>>V1.54
1) Add Gaia's decoding format configuration function//To be paired with Gaia APK V4.2.2, Bluetooth decoding format can be turned on/off within Gaia//
2) Add Gaia touch switch configuration function//To be paired with Gaia apk V4.2.2 and iOS Gaia 1.2.7//
3) Modify the shutdown time without data to 30 minutes.//The original automatic shutdown time without data playback has been changed from 10 minutes to 30 minutes//
4) Increase the battery level of the display device in Gaia//Gaia apk V4.2.2 allows you to view the Go pod battery level//
5) Added support for factory reset in Gaia apkV4.2.2. For example, restoring the initial Bluetooth name, resetting the switch settings, and clearing the memory device//
6) Performance optimization and bug fixing
Android app available for download, iOS hopefully popping out as well sometime soon.
gryffe
- Jun 11, 2014
I'm having a brain freeze. I've updated GO Pods to V1.54 using GAIA app on android phone, but can't update the GAIA app from 4.1.95 to 4.4.2. The file is downloaded on my phone but for some reason the GAIA app is still on previous version. Can someone refresh my memory as to how to get the GAIA app to pick up new version?
Thanks
Thanks
Risking stating the obvious - did you just download the apk or installed it in OS as well?I'm having a brain freeze. I've updated GO Pods to V1.54 using GAIA app on android phone, but can't update the GAIA app from 4.1.95 to 4.4.2. The file is downloaded on my phone but for some reason the GAIA app is still on previous version. Can someone refresh my memory as to how to get the GAIA app to pick up new version?
Never mind, android apk package is broken. Oh well…Risking stating the obvious - did you just download the apk or installed it in OS as well?
gryffe
- Jun 11, 2014
Like me are you getting an error "App not installed as package appears to be invalid"?
Correct.Like me are you getting an error "App not installed as package appears to be invalid"?
gryffe
- Jun 11, 2014
Cool, I thought I had messed it up somehow.
Uninstalling existing version helps.Cool, I thought I had messed it up somehow.
amf.123
- Jan 27, 2007
Does anyone else have issues with the pins sticking down in the charging case? It happens to mine all the time. A quick tap and they pop back out but I fear one day they may not
I've successfully updated both the App on my Samsung S23 Ultra and the Firmware on my GO Pods. I appreciate the battery level indicator on the GAIA App
Regarding the shutdown time, from 10 to 30 minutes, I am OK, I'd prefer a way to shut them down without having to place them back into the case. In a recent ticket, iFi Support told me it is not currently possible but they will consider it in a future update
Codec configuration is also nice!
The GO Pod is an amazing device! I got the SIMGOT EW200 few days ago. Unbelievable how they sound with the GO Pod!!
Does anyone know what the "Bit Perfect" filter does? @iFi audio ?
@amf.123 nope, not on mine. Better contact Support
- Mar 20, 2013
Thanks for your thoughts here, I will inquire for you on the BP filter, this is on other devices so getting an answer for you should be probable, sometimes specific on certain things in devices is a bit hush-hush, but I will ask.I've successfully updated both the App on my Samsung S23 Ultra and the Firmware on my GO Pods. I appreciate the battery level indicator on the GAIA App
I am glad you are still enjoying them!
Cheers!!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
