Thank you for posting your impressions here!
Enjoy.
Cheers!!
Enjoy.
Cheers!!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
@iFi audioThe GO pod launches on 14th April 2023 at AXPONA (Audio Expo North America) and the 1000 ‘GO pod + IEM’ packages are available to order from this date. 60 days later – or when these packages have all sold through, whichever is sooner – the GO pod will be made available as a standalone product to combine with any pair of IEMs.
We are currently asking this to get an answer, as soon as we have a firm answer I will be sure to post it up here for you!@iFi audio
@Mr BubbaHyde
60 days after 14 April 2023 was 13 June 2023. Is the GO Pod available in the UK now? If so, where?
It is not available on your website. When will it become available on your website?
Is your issue music cutting in and out, or losing bluetooth connection on one side but can still hear music playing on the other? That’s one of my issues is that I would lose bluetooth connection at random on either the left side or right side. To fix I would have to hit disconnect on my DAP to stop the connection and then reconnect again.Issue with sound cutting in and out now a couple of times. Happened the other day. Rapid cutting in and out of music mostly from the right earbud. I thought it might be a Pixel 7 LDAC issue, and I was walking my dog so I tried switching from Adaptive LDAC to aptx, and it still kept cutting in and out so I just dealt with it until I got home. Everything was great on the 5-6 listens with them since. Then just this evening the cutting in and out a lot started happening again, and a lot.
This time I troubleshooted. I tried switching back and forth from Best Effort Adaptive LDAC to Apt x, same thing. Then i turned HD Audio off and used SBC, same thing. Then I turned Bluetooth on the phone on and off, the Pods reconnected and same thing. It was really annoying so I looked up the controls of the Pods on my phone and held both touch panels down simultaneously until they reset.
Once the Pods rebooted and reconnected and I played music again, problem solved.
I'll see how often this keeps happening. My phone is still on the May security update, so nothing has changed with my OS in the last month.
I submitted a ticket with iFi a week ago and so far their responses have not been helpful.
I’m hoping iFi can answer my ticket and tell me where to send my Go Pod so they can fix it.Same as you, it's on one side, on the other either the music plays at the same volume or changes volume but does not cut out.
Hi there! I’m thinking about doing one of those combos, either GO pod & ie900 or utws5 & ie900. Fo you mind posting a link to the adapters you have?? Thanks!!I tried it with Andro2020 and ie900 as well. Interestingly it drives the ie900 well enough. I can't say this from the utws5. Utws5 is so much better with only BA IEMs. I fit is a little bit awkward, but manageable. (you do need an adapter because the recessed socket) It shines with the Andro though. I prefer the Andro with the better tuning until PEQ available.
IMO this is the first adapter which can drive DD IEMs well enough to be used as a tws.
I had this issue a couple of times especially when cycling however seemed to resolve itself and not had it for over a weekIssue with sound cutting in and out now a couple of times. Happened the other day. Rapid cutting in and out of music mostly from the right earbud. I thought it might be a Pixel 7 LDAC issue, and I was walking my dog so I tried switching from Adaptive LDAC to aptx, and it still kept cutting in and out so I just dealt with it until I got home. Everything was great on the 5-6 listens with them since. Then just this evening the cutting in and out a lot started happening again, and a lot.
