officeboy20
- Feb 17, 2014
CIEM. it wont fit in the case so I have to disconnect the CIEM from the Go Pod to close the case.Is your GM universal or ciem?
Go pods cope with controlling these headphones? is there enough power?Sharing you my Go Pod with Fatfreq Grand Maestro. Sounds sublime
yes, can be easily controlled thru the touch area/buttons. but most of the time, I disable it and just control it thru the phone/gaia app.Go pods cope with controlling these headphones? is there enough power?
Awesome to hear this!yes, can be easily controlled thru the touch area/buttons. but most of the time, I disable it and just control it thru the phone/gaia app.
And yes, Go pods can drive my GM pretty well. goes around 50-60% volume only
Stay updated on iFi audio at their sponsor profile on Head-Fi.
1. Yes, it does charge when the case is not closed.1) Does case charge with not closed?
2) Wouldn't continuously disconnecting CIEM from go pods affect the 2-pin fit tightness overtime?
@iFi audio hope you guys can just make the case significantly bigger. It's basically transportable at this point anyways.
Would that be a bigger brother or updated version this year?I have, and if I had anything specific to post I would have.
There are GO Pod changes in the works but in terms of what you asked no news to report.
Although this would be a logical step to me specifics have not been identified.
Will there be versions or improvements certainly but specifics won’t be known for a bit.
Cheers!!
If I were to ask my trusty (and old) Magic 8-Ball, the answer would be...Would that be a bigger brother or updated version this year?![]()
Does it has enough power to drive Anni? what's the yellow patch for?
sofar, yes. pretty good synergy for my ears. but i have to set the volume of the Z-Fold5 at around 60-80% to make the Anni sing.Does it has enough power to drive Anni? what's the yellow patch for?
