bmazzeo
Different menus for Android and IOS. Wonder if the capabilities are different or there is parallel development for the two platforms. The ability to adjust sensitivity seemed promising. Not clear it’s available for Apple.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I am seeing this as well.Been reviewing the older posts in this topic today. @Mr BubbaHyde has stated that the sensitivity setting is available in both Apple and Android versions of Gaia. Why don’t i see it? I’ve noticed that not all the menu items always display whenever I pair the Go Pods. Is there a way to get the sensitivity parameter to appear?
No luck.For the folks who are having the Red/Green Flashing issue here is some info I have gotten while Tech support is getting to you.
Flashing red and green indicates loss of contact between the left and right ears.
Please ensure that the ear hooks are as close as possible to complete the left and right interconnection properly.
Try the following...
1. Press and hold both ear hooks simultaneously for 12 seconds in the touch area to restart.
Let me know if this works for you that are affected.
Cheers!!
Thanks for trying, I will update the folks that gave me that bit of info.No luck.
They both went to a light blue light. The left pod (that works correctly) continued to have the LED off, and the right pod went back to flashing red and green.
Edit: I tried it with the pods back to back and again with the pods right next to each other, either way, same results.
I am he, lolIFi Support (Liam) closed my ticket #182933 for lack of activity. Apparently they missed my email regarding experiencing the sudden volume increases. I re-opened the ticket and updated it with my recent experiences.
I am hoping the sensitivity adjustment setting will help and waiting for @Mr BubbaHyde to investigate why that is no longer on the current IOS Gaia menu. I am running 1.5.4 and verified that is what is being downloaded from the iFi site for IOS.
I have asked this question, and sometimes answers do not come as quickly as even I would like, but they do come.I found instructions on the web adding the capability to the Amazon Fire Tablet to access Android Apps (https://www.wired.com/story/how-to-install-google-play-store-on-amazon-fire-tablet/) and verified my old Fire HDX tablet has blue tooth capability. But the instructions seem difficult. It involves downloading 4 APK files at the appropriate software level to my old tablet.
@Mr BubbaHyde, did a older version of IOS Gaia have this sensitivity adjustment capability? It would be much easier for me to do a one off update with that versus going the Android route.
That very well may be, kind of why I am thinking the sensitivity may help you out.@Mr BubbaHyde ,I went ahead and ordered a cheap ($200) Android table from Lenovo. I am traveling the next 2 weeks so it will be a while before I can try it. I am making a project out of adding Android capability to my Kindle this week. Learning how to use it again is half the battle. If unsuccessful, I can fall back on the Lenovo tablet. So if IOS didn't have the capability, I now will have a work around to access the sensitivity setting.
Yesterday, the volume issue did not occur at the gym, but then the Go Pods shut themselves off and back on as I was about to put them away. As no buttons were pushed, I think they may be sensitive to movement (perhaps when combined with sweat or body heat).
