gregorio
- Feb 14, 2008
"If you think of mains power as the ‘gasoline’ fuelling your audio system, the AC iPurifier is the product that ensures that it’s getting a clean, super premium blend to deliver the best possible audio fidelity."
OK, let's think of it as gasoline. 1. If you add some sort purifier to your premium blend, it does NOT suddenly become a super premium blend, that's defined by the refinery, not by some purifier/filter. 2. In the case of dirty gasoline, adding a purifier/filter will make the fuel cleaner and your engine run better, which is why every competent car manufacturer ALREADY includes a fuel filter and therefore adding another one achieves NOTHING! So it is with say a DAC, any competent DAC has to take mains power, convert and in the process purify/clean it. Adding another "purifier" before the built-in purifier does absolutely nothing unless you have an incompetently designed DAC which doesn't have a competent purifier. However, rather than spend $300 trying to compensate for this single aspect of an incompetently designed DAC, I'd rather spend it on curing all the incompetently designed aspects in one go, by buying a competently designed DAC in the first place ... but that's just me!
G
G
