For anyone reading this in the future I purchased this:
TRN 8 Core Knitting Silver Plated OCC Copper IEM 2.5/3.5mm Earphone Audio Cable
For $10 on ebay and it is incredible quality. Might as well buy a couple! As good if not better than the fearless stock cable. To be honest I A/B'ed them probably 7/8 times w/ good seal and a dark room and could not tell any difference. If anything the TRN cable was sharper/crisper but I likely could not tell a difference were I blindfolded.
It came in a very aesthetically pleasing package it felt like I was unboxing an apple product. I could not believe the quality and presentation of this product. I'm going to order a few of the unbalanced ones for future use.
The "Fiio square braided cable with 8 pieces of OCC silver plated wire" was neither 0.78mm or 0.75mm - it was larger than either so the seller kind of ripped me off on this one claiming it was a 0.78mm. Go figure the name brand one didn't work and the generic was great.
tldr;
You don't have to pay $150 or even $50 on a cable to get good quality out of a high-end set of IEMs in my opinion.
That's good u found your cable! But I read in this thread that some TRN 8 core cables have unsoldered wires: https://www.head-fi.org/threads/trn-impressions-thread.881761/page-40#post-15037249
Seems the 16 core ones are ok.
That was a few months back though, not sure if their newer batches have fixed the problem. U can always use a multimeter to measure though.
