IEMs for sleeping - any others to try?
Jan 12, 2024 at 1:00 PM Post #16 of 18
I should have put into my original requirements to be 100% radiation free. I put the phone into airplane and use wired IEMs only. Absolutely no way I'm going to use anything wireless all night long.
This is why they are consumables and need to be inexpensive as the wire will get damaged from time to time.
I had the same concern about Bluetooth radiation, but the literature on Bluetooth having health concerns is inconclusive at the moment. I do get what you are saying though, better safe than sorry.
If you are using moondrop's standard tips, those don't grip all that well. Azla Crystals are quite grippy so those might work better. Moondrop's IEMs also seem to benefit from using long stem tips.
