Santamaria
- Feb 11, 2008
It has worked just fine for me with spinfits and final A8000.You can pierce a hole in any silicon tip. This little hole will not affect the noise cancelling but will let the pressure to equalize no matter how deep you pushed your iem. I've been using this for a decade because my left ear somehow tries to reject the iem and removes the bass in several minutes of listening to vacuum iems. This never happens with iems that has vents in them.
The pierced hole should be in the right place so your ear will not close it (for spin fits you can pierce from inside through the place that makes spinfits what they are). Also after this you should remember which of 2 tips is pierced and not to tear them apart while removing.
It helps me, but may be no help for you, you should understand that you can waste your ear tip. The point is that this little hole closes by itself when there is no pressure or it is not enough to escape, that is why it doesn't affect the noise cancelling. Use this advise at your own risk. Also give your iem a moment for this hole to work, since it is small and closed by itself it works not instantly but very mildly. I have never pierced 2 holes, 1 was always enough.
Let me know if that helped someone, I would be happy. Because this issue driven me mad and I would pay for this solution back in a day![]()
GRATEFUL
