surfgeorge
Member of the Trade: 3D Printed Accessory Designer
Let me put it this way - I can listen to my IER-M9 directly connected to my old iPhone SE but I never do, because the iPhone sounds dead. The M9 scales with the source and I assume the M7 as well. That's why I always carry the Mojo2Poly with me and often use the M9 with my Hugo2Go at home. That latter combination is stunning in it's detail, imaging and liveliness! For your use case just get as good a dongle DAC as you can justify. The M7/M9 have a laid back, warm and smooth sound and should pair well with DAC that's a little more energetic.Can they be driven with some type DAC/amp like the ifi gobar using an iPhone? I do use Tidal and Quboz app on my iPhone. So, when in the car, and not using the headphones, I would want use something between my phone and the Apple CarPlay…
kind of multi-purpose…. BTW, this would be a more mobile (not wearing on the go) as I go between my homes. Also, I’m more of an R2R DAC person, at least for home use…
Also consider tip rolling - the M7/M9 are quite sensitive to tip choice. I ended up with the Sony EP-NI1000 foam tips after going through dozens of choices.
