IEMusic
I personally would have to completely disagree with that someone. The 3DT has a little more bass than the OG MEST, with a more even sub bass to mid bass distribution (OG MEST seems more sub bass biased to me), but it is FAR from being a bass head IEM. If one were a bass head, one would be disappointed in the 3DT. It has a very fast, agile, and textured bass, similar to the MEST’s. There is adequate bass on the 3DT, but not a ton. It is certainly also not neutral though. I actually boost the sub bass a little on my 3DT, since the upper mids and lower treble are more boosted relative to the bass. The 3DT, like the DQ6, is a unique experience. It is not like the MEST, or any other IEM that I’ve heard (except the DQ6). No other driver make-up has yielded similar results for me. Timbral accuracy is amazing. Instrument separation and imaging are also very well done, though it’s not as holographic as the MEST is. Clarity and upper midrange/lower treble detail is off the charts. I know many may disagree with me on this point, but I have found the 3DT to be the overall most detailed IEM I’ve heard thus far, and that is with extra damping in the form of a Moondrop filter.I’ve heard 3DT is good for bass, but had someone has both strongly advised me of No-go for buying 3DT. Said “if you are not basshead, there is no justification for buying 3DT, if you already have like MEST or RSV. Maybe 3DT works great with certain impactful genre like metal though.
For bass, I find the speed, transient attack, decay, texture, and detail to be roughly similar between the OG MEST and 3DT, both being superb. If one likes really extended treble air, with very shimmery cymbals, go for the MEST. The 3DT has adequately extended treble for me, but it is not as prominently extended as on the OG MEST. I actually use EQ to roll off the treble a little on the OG MEST, to make cymbals (especially hi-hat and ride) more realistic sounding, and less splashy. If you like a more prominent upper midrange, with more “bite” to female vocals and guitars, the 3DT tuning is more ideal. If you like more treble detail than perhaps you’ve ever heard, go for the OG MEST. Both are extraordinary with all metal genres.
One thing to reiterate is that the tri-DD IEM is a unique sounding IEM, and there are some people who don’t really perceive it in a delightful manner. My recommendation would be to get the very inexpensive KZ DQ6 first, and if you really like the overall sonic qualities, then go for the 3DT. The 3DT is better in every regard IMO, except for sheer bass quantity, which the DQ6 has more of. I like the DQ6 with metal as well, but the DQ6 tuning is more V-shaped than the 3DT.
So, if you have and like the excellent MEST and RSV, than there is certainly no NEED to get the 3DT, BUT the 3DT is still a very different sounding IEM, nothing like either of those 2 IEM, and is completely justifiable IMO. More justifiable than many other IEM purchases.
