So wrong.
The trend of "people who can sell anything they build" towards cabinets that weigh in the 300lb range, and are SPIKED to the floor is not an accident. The speakers DO set up resonances in lightweight cabinets, and by coupling the speaker to the floor you increase its mass several-fold. A light speaker on a suspension is free to sway to the music in a manner mildly related to the actual signal. Some call this distortion.
Rigidly couple the speaker to whatever its sitting on. If the speaker is on a stand rigidly couple that to the floor.
By all means, experiment with any manner of suspension you can think of, but the rule of thumb says to rigidly couple speakers to the floor. Start off following the rules.
Please do not be rude and try to understand.
There is no benefit in increasing the mass of the speaker cabinet.
The speaker cabinet as a whole will not move to follow the driver.
The reason why speaker stands are sometimes sold with a very heavy mass is simply to stop the stand itself from conducting vibration as I have described. It is not to add mass to the speaker.
If you rigidly attach the speaker to these very heavy stands then all you do is set up resonance points within the speaker cabinet where you have rigidly fixed the speakers.
So, the best way to place the speaker on these stands is to use blu tak, which of course is common practice and a good one.
Those heavy stands come with spikes for the floor, but these are a good way to make sure the stands are stable in most carpeted homes.
With respect to this issue of speaker stands, I very much favour using lightweight stands and using large bicycle inner tubes (700 C) at the base.
The bicycle inner-tubes prevent points of resonance and you will find, I think to your surprise, that the lightweight wooden structure, vibrates very little.
This, of course, is because vibration requires nodes. If you don't provide the nodes there will be no vibration.
The most classic way to describe this is the example of a 12 inch ruler. You clamp this ruler to a desk and then you can make a very nice "twang" sound.
If, however, you undo the clamp, you cannot make a nice "twang" sound with the ruler any more because there is no longer a node as a reference.
