Ideal Headamp for vinyl; Tube or Solid State?
Sep 9, 2009 at 4:26 PM Thread Starter Post #1 of 13
IceClass
I was curious as to whether serious vinyl and headphone listeners have a preference for solid state over tube or vice versa.
What do you prefer and why?
Sep 10, 2009 at 2:23 AM Post #2 of 13
Skylab
Reviewerus Prolificus
The Court of the Crimson King
Well, I listen to my Vinyl rig with a tube Darkvoice 337, and it sounds terrific. But I prefer tube headphone amps in general - with vinyl or digital
Sep 10, 2009 at 6:23 AM Post #3 of 13
IceClass
I was rather wondering if solid state might be too revealing of surface noise.
Sep 10, 2009 at 12:40 PM Post #4 of 13
Skylab
I don't think that's an issue generally - my 337 reveals detail as well as SS amps do, and so I think it would not be different in that respect. What you need to minimize surface noise is clean records
Sep 10, 2009 at 1:46 PM Post #5 of 13
BigTony
The aim of all amps is to 'amplify' not to disguise/modify the input signal. Most decent amps will not add anything to the signal (i.e. hiss or humm) or any unwanted distortions. You'll find changing your headphones will have a much larger effect on the sound than switching amps.
Sep 10, 2009 at 4:53 PM Post #7 of 13
niemion
Skylab, how does the Decware CSP2 sound with vinyls if you compare it with the Darkvoice?
Sep 10, 2009 at 8:46 PM Post #8 of 13
Skylab
The CSP-2 is a great amp. As such, it sounds great with my Vinyl rig
Sep 11, 2009 at 2:24 AM Post #10 of 13
Clarkmc2
Since specific amps are being inquired about, I admit I know of one of the best. The Grommes PHI-26 is a Preamp-Headphone-Integrated amp of about two watts triode and six watts pentode. Roll in 6P14P-EV power tubes (ten dollars each from the right source) and it is the best amp I have ever heard, period. It has plenty of power. It makes it difficult to put the volume past nine o'clock when driving Stax SR-X Mk3s through an adapter, in triode mode.
It was voiced for Grados but works with any dynamic headphone. Designed by Alan Kimmel, it is $995 US. A bargain that sounds like $10,000. The rub is that it usually takes six months to get one built. It is worth it. Highly, highly recommended. Everyone who I auditioned it to has bought one.
There are pre out jacks. The preamp section has 30dB of gain, and no audible distortion. The power amp stage - there are only two gain stages - does not have to do much and sounds just as good. Turning the volume control all the way up with no input signal results in no noise at all, dead silence. Alan is a genius.
I have two, having bagged the only used one I ever saw. There are probably less than thirty in existence, but they have thirteen dealers.
Clark
Sep 11, 2009 at 2:34 AM Post #11 of 13
niemion
Originally Posted by Clarkmc2 /img/forum/go_quote.gif
Since specific amps are being inquired about, I admit I know of one of the best. The Grommes PHI-26.
I've read that the PHI-26 should be able to drive ordinary speakers, is that true?
Sep 11, 2009 at 2:49 AM Post #12 of 13
Phelonious Ponk
I am pretty much settled into single ended tube amps, but you might enjoy this from the designer I favor.
Myths That Plague Tube Audio © 2001 Alan Kimmel
If you have no interest in the rest, skip to #5.
Clark
I think headphone audio, where watts are measured in millis, and headroom is rarely an issue in anything that plugs into a wall, is a perfect place to maximize the potential of single-ended tube amps.
P
Sep 11, 2009 at 2:50 AM Post #13 of 13
Clarkmc2
It has the strange ability to drive almost anything. I use 97dB/watt/meter single driver augmented Hammer Dynamics Super 12s and the nine o'clock position in triode is comfortably loud. The 18" woofers in my big JBL four ways were a little loose with the PHI, but that is a pretty demanding setup. I settled for a biamp setup that let a bigger tube amp cover the woofer and everything sounded great. I would say any reasonably efficient speaker would be OK. The transformers are very special and Alan says any tube that will fit is OK.
There was a legendary encounter where it was demonstrated able to drive a pair of Martin Logans better than anything else in a high end shop!
I understand that the old Welbourne kits Alan designed are going for twice the original price, built and used. He designs for Modwright now, but I can't afford their products.
Clark
