mkmelt
- Jun 14, 2002
If you want a model with a rotary balance control, but don't care about the midrange tone control,then consider the 1030 integrated amplifier (like the 1060 but less power, fewer controls) or any of the following receivers 2215,2220, or 2230 would be good choices.
If you want both a rotary balance control and the midrange control, then your best bet would be the 1060 integrated amplifier or the 2230 receiver.
The midrange tone control is one of those features that was common on 70s gear that was later dropped to keep costs down. The benefit of the midrange tone control is two-fold. It gives you the ability to tweak the midrange response (the Marantz mid-range control is centered at 700 Hz). With three tone controls, the bass control turnover frequency is usually chosen to be lower, at say 50Hz, and the treble control turnover frequency to be 15KHz.
Many times, when there are only two tone controls, the bass control turnover frequency is raised to 150Hz or even higher, and the treble control is lowered to perhaps 8KHz. This type of bass control is useless for compensating for a given speaker's bass response in the lowest range without also mucking up the midbass.
