rickster, help me out here, but on one of the links you provided here on another thread it talked about 1st, 2nd, and 3rd order effects of the variable of cables, where 1st order effects had the most effect on sound and 3rd order had the least or most indistinguishable effect on sound for cables. I believe cable construction is a 1st order effect, whereas type of wire used is a 3rd order effect; according to this article which i hope rickmeister can help me find again, that means the wire whether its copper or silver has the least effect on sound vs. the actual construction and braiding of the wire itself. |
yes,construction geometry is the most audible all things being equal (and usually they are not
) and that is why you see so many variations of cables from different companies that use the same type of wire internally but yet sounding so different.
If it was JUST silver vs. copper it would be an easy choice
maybe but even length of the cable makes a difference.
I will be damned if I can acually hear any difference in one #24 wire from another when it is internal wiring of a project being used as the test (and i keep all wiring short anyway) but as soon as we get to the 3-6 ft length sound becomes a factor and simply swapping cables in and out have perceptable sound differences.
Is it the jacks ? The solder ? Wire ? Construction
method ? All ?
I can even take three cables using the very same magnet wire or the identical silver wire but each using a different construction method and THAT will sound different !
So I think while all have some effect it is mostly minimal until you come to interconnect topology even though I can not prove this.
I am also convinced our mind plays tricks and an ugly cable sounds ugly and a pretty one sounds good so the cable manufacturers put as much effort into the "look' as they do the actual method or science so maybe there should be a category #4 added- "cosmetics and effect on sound quality".
If I was extremely paranoid about this I could spend the rest of my life swapping and listening to interconnects but life being short I just say screw it and use the same wire for everything but a couple of areas (I use the silver at the front end for turntable to phono stage connection).
That is the #22 enameled copper magnet wire which internally is twisted pairs and externally,the actual interconnects with plugs the PBJ clones or PBJ/XLR cables depending on cable length and if it is a SE or BAL connection.Three actual wires and all covered with teflex just to pretty it up and make these "whimpy" feeling cables have a little more sustantial "feel".
I still experiment from time to time but in the end have no urgent need after these experiments to change out all my interconnects for anything new and once past the source to line stage connection I don't like a mix and match approach to connections.
Again the "imagination" thing and mind games.
Yes it sounds different but is this new sound a better one or just different ?
And how do I know if it IS if I do not change ALL the cables from the front end to the power amp/headphone amp ?
I have noticed just from screwing around that whatever part of the signal path has the most coloration and the largest perceived difference is a bad thing becasue if transparent how would you know it was even there ? so by dominating the sound,the "WOW ! THAT SOUNDS GREAT !" it must be
coloring the sound right ?
I think maybe the best cable is the one that when you swap it in does not jump out but just allows a tad more information to flow through,maybe just a bit less conjestion, and it is my personal opinion these are usually the most simple designs and using a small guage solid conductor be it
silver or copper.
then again,if I had all the answers maybe it would be me making and selling cables so I just kick back and let the music play and leave sweating the details to others.
I just provide the links man so folks can do the research but I never said I agree with everything-down that path leads madness because none of the "experts" seem to agree on anything
Rickster,wired and ready
