triodesteve
- Jul 26, 2003
I'm not sure yet, but will find out. Could be a great solution for using Airport Express elsewhere in the house.
Originally Posted by saxphile Interesting, I'm planning to do the exact opposite. I'm going to get myself a SACD player and a proper amp because I'm starting to find my current setup (iBook + TBH) lacking in certain respects. Well the TwinDac is probably on another level than the bithead. Filterless, passive conversion (resistor and transformers), 4 SLA batteries and a very trick charging system. The transformers alone probably cost more than the Bithead. I was using an Onkyo outboard usb d/a for a while and it was only ok...not the equal of the Sony for sure. Don't blame the computer...it works great as a trnsport, but you need a good dac. What amp did you use with your SCD777ES? I'm not a headphone listner at home (please don't throw me out). Amps in my system are the Final Labs Music-6 for the top end and a NEW DCA-33 for the bottom end. BTW, bluetooth remote? But how far away can you get when you're using headphones? |
