Passenger11
- Jul 8, 2016
I personally like the current version 6.0.Just wondering which firmware sounds best? I just brought this and currently in 1.3.
I think the dx80 always has issues with album art. My DX80 doesn't show album art for some of my tracks that just uses a folder.jpg, and most if not all of my cued lists doesn't show album art.
1, always have your album art named 'cover'
2, keep the album art in the same folder as the music
3, Update all album art using mp3tag
I have no issues anymore with album art not showing
By the way, do you clear your SD card from MacOS stuff before inserting it into DX80? You'd better do, because it may be the cause of problems!I'm using a mac
Ah, no wonder. Mine is all folder.jpg. I'm using a mac, is there a good id3 tag editor for mac?
I DONT tagg on mac as it often disappears !! - to reliably tagging (for work purposes) I only use a PC
MP3tagg for mac is one of the most reliable
Hmmm, it says it is for mac. Try this one:seems like it's for linux or windows only. It downloaded a tar file for me.
Sorry, that one is quite old, try http://brewinstall.org/install-easy-tag-on-mac-with-brew/Hmmm, it says it is for mac. Try this one:
https://www.macupdate.com/app/mac/23207/easytag-app
I mean a tool like CleanMyDrive. I'm not a Mac user, only heard about it, but Mac users often give me flash sticks, SD-cards and zip archives with junk.I don't know what you mean by clear, but I always eject them before taking the sd card out.
