iBasso DX300 MAX Dual AK4499 Snapdragon 660 Octa-Core 6GB RAM 128GB ROM NEW Firmware: 2.02Available.
Sep 10, 2021 at 6:16 AM Post #2,296 of 5,029
As we are talking about EQing, here is some information fro the newcomers. You may find the information insufficient, or the wording not good, but it is a good place to start. Here we go...
Also, if you would like to EQ, for example according to Harman target, here you can find PEQ settings for many headphones. I would take them as templates, rather than exact hard set values. For example, for Kennerton Thekk, I use one third of the gain values.
Let's take an example, Kennerton Vali:
https://github.com/jaakkopasanen/AutoEq/tree/master/results/referenceaudioanalyzer/referenceaudioanalyzer_hdm-x_harman_over-ear_2018/Kennerton Vali
Best post ever
Sep 10, 2021 at 8:13 AM Post #2,299 of 5,029
Guys I tried USB DAC mode again. It works by not plugging the usb before switching to usb dac mode. But the problem is after you exit, twice I lost the sound from the right earphone and had to restart the unit twice to get it back. And one instance is after exiting USB dac mode, it won't output music aside from hissing and crackling.
Sep 10, 2021 at 8:16 AM Post #2,300 of 5,029
I remember a similar issue back in DX220 days, but don't remember the exact scenario.
Sep 10, 2021 at 8:51 AM Post #2,302 of 5,029
Sorry, but i cannot confirm that behavior with my macbook. Tried all combination (first switch on DAC then connect, or connect and afterwards switch to DAC mode, then switching on DAC while playing music with Mango, then with NMP, with UAPP, etc different interruption of playing music by switching to DAC mode) works just fine. Could that problem be connected only to using Windows-based PC?
Sep 10, 2021 at 9:10 AM Post #2,303 of 5,029
Could be. I am using windows 10, razer blade laptop
Sep 10, 2021 at 9:43 AM Post #2,305 of 5,029
Maybe macOS requires a driver's installation for XMOS?
wait does this dap use an XMOS chip like the 220 daps?
https://www.xmos.ai/software/usb-audio/driver-support/
Sep 10, 2021 at 10:35 AM Post #2,306 of 5,029
Upto your source files. If you have 44.1 -48 then 16x for 3Max, and slide it accordingly to scale
I bought Neutron yesterday and it is indeed a really great player after I applied your recommended settings. A bit fuller sounding than pure Mango OS but still clear and detailed. I applied 16 x oversampling.
The thing I don’t understand is when oversampling 24/192, the DAP output is 705,6 kHz like it’s a 44,1 multiple instead of 768 kHz a multiple of 48 kHz. When I play a 24/96 track, it shows the correct 768 kHz frequency.
Do you have an idea of what is wrong?
Sep 10, 2021 at 10:38 AM Post #2,307 of 5,029
Do share your experience after. :)
Wow! OK. Now I thought Mango was pretty good.. but this Neutron player is brilliant especially with Whitigir's settings! Compared to Mango... which is great.... there is much more transparency and separation of instruments together with sounding more true. Bass, Sub Bass, Treble and Vocals are spot on. Will continue listening and comparing. Until Ti is delivered in a few days time.Then it starts all over again. 🎧
Sep 10, 2021 at 10:39 AM Post #2,308 of 5,029
Do you have an idea of what is wrong?405A106B-CCF4-47D0-84AA-00A0AA438CB0.jpeg
Only apply 16X, the maximized OS on files of Nyquist standard or Redbook 44.1 to 48
Anything higher than this will meet with truncation (in a sense, a degradations to properly achieve mathematical models)
I recommend 192 will be maxed out at 4x . Give that a try and see if 768Khz shows
Sep 10, 2021 at 10:41 AM Post #2,309 of 5,029
The effects is further strengthened with MicronSD or Sandisk MicroSD
This is the proofs of how important digital bit accuracy and error corrections algorithms is in places for our hobby
:wink:
Enjoy your new found advanced player
Sep 10, 2021 at 10:43 AM Post #2,310 of 5,029
Hey Lappy27! What a coincidence we're both playing Diana Krall after setting up Neutron! 🤣
