How it it is comparable with Cayin m6 mk2 with E02 or Astel Kern se200 ?
iBasso DX220Max ****************** New FW! 1.01 for download! 1st Page.
- Thread starter Paul - iBasso
- Oct 6, 2013
Despite all the nerve wrecking discussions, why it is for me so difficult to let the MAX go: It just sounds good. Here is a Chinese site comparing MAX to M15, R8 and QA390.
Original: https://www.sohu.com/a/404101599_120202585
Translation: https://translate.google.com/translate?sl=auto&tl=en&u=https://www.sohu.com/a/404101599_120202585
The M15 comparision is spot on matching to what I think: MAX has clearer sound with more extension in low and high ends of sound spectrum. The mids of M15 are slightly better than MAX (which it shows with its velvety vocal rendering). "The biggest problem is that the overtone of the instrument is not as rich as MAX. A piano solo can be clearly distinguished."
For R8: "R8 is a very magnificent trend, dynamics take precedence over details, and MAX is the reverse, using details to build dynamics. So in terms of style, R8 is more suitable for classical music that emphasizes momentum and dynamics, but in terms of vocals, it can't be said that it is not good at it, only that it does not have the extra points like deducing classical music. However , the balance of MAX is a little more moderate than that of R8 . Both the vocals and the classics are OK."
I looked through that write up twice, and still not sure which IEM or headphones they used during comparison. I do see MEST and Grado in some pictures, but not sure if they used it for testing or just for pictures. Just trying to understand the sound relative to pair up synergy.
- Oct 14, 2013
It is on Loan , and the last time I listened to it on dx220, it was fine. There must be some differences in firmware between bothVince, can you try exactly the same files on you DX220?
behemothkat
Yep, interesting observation. I really hope for more “optimizations” in MAX software.It is on Loan , and the last time I listened to it on dx220, it was fine. There must be some differences in firmware between both
ayang02
The original article mentioned these IEMs & headphones were used for the comparison:
-Simphonio VR1 (an aftermarket cable was used here? Not sure which one)
-Tingpod Aurora 3
-Grado MPRO (05 version? I’ll assume this means 2005 version)
- Oct 6, 2013
-Tingpod Aurora 3
Got it, thanks! Looks like all mid-forward bright tuned. Just want to have some relative perspective.
mathfi
- Aug 10, 2010
Hello: Just bought DX220 max from bhphotovideo last week. First I noticed that there are two battery indicators. The right indicator, however, won't hold a charge (it keeps decreasing). The system has been giving me low battery warnings based on the right battery indicator. I used the included power supply to charge the DAP, however, the charging does not seem to work (or do anything) on the right indicator. Does anyone have a similar problem? Thanks in advance - mathfi
You need to use a USB charger through the USB-C port in the middle. DX220 Max has 2 independent batteries; one for analog amp and another for digital system.Hello: Just bought DX220 max from bhphotovideo last week. First I noticed that there are two battery indicators. The right indicator, however, won't hold a charge (it keeps decreasing). The system has been giving me low battery warnings based on the right battery indicator. I used the included power supply to charge the DAP, however, the charging does not seem to work (or do anything) on the right indicator. Does anyone have a similar problem? Thanks in advance - mathfi
mathfi
- Aug 10, 2010
hah ok! thank you, I guess I should have read the manual first! I tried the USB-c and yes, it is charging now.
Shawnb
- Dec 2, 2012
Here's the link for the manual if that helps as well
https://drive.google.com/file/d/1nCDscIYfnpuZ7tZc6nBJsUjkp8CNOKE0/view
SE200 is announced like, yesterday?
jmills8
Previously known as bmiamihk, jmills2
SoSE200 is announced like, yesterday?
jmills8
Hope it sounds better than the SP2000.I am sure you must have tried it 6 months ago.
behemothkat
No; it must still burning in: since you have multiple DACs burning process will take minimum twice time longer.I am sure you must have tried it 6 months ago.
Total: 6 (members: 0, guests: 6)
