bluedolphin
- Feb 27, 2011
I apologizes for everything i said
Here's a question for anyone that has tried out some of the different amp modules with the DX150: I do enjoy how it sounds with the stock amp, but sometimes it is a bit too forgiving, where I feel like leading notes are soft amd don't have much impact. With my Noble Katanas, some small details go missing, compared with my other DAPs. What other amp modules would you recommend?
So in your opinion, what would be the amp module that has the fastest attack and most analytical sound?Before you jump into amp-rolling, have you tried going through digital DAC filters of DX150? Not everybody hears the difference, and in your case the Katana is not the most micro-detailed or analytical to begin with (compared to K10 and Encore). But considering you just mentioned "... feel like leading notes are soft...", it sounds like you are hearing a slower attack of the notes. Filters do affect the sound in a subtle way, and can help to fine-tune the sound. See if that can make a difference. For example, with Sharp Roll-off I hear a faster attack and more sparkle, with Slow Roll-off I feel the attack is a little slower while sparkle is the same, and Super Slow Roll off has the slower attack and less air/sparkle in comparison to other filters. The effect is subtle, but noticeable to my ears (using U18t w/Horus for listening).
Another thing, try Lurker's FW. I can't say it for sure since don't have a way of doing direct a/b comparison, but it felt like it took a little edge of smoother sound tonality of AMP6. I could be splitting hairs here, so take it with a grain of salt.
I see, so the AMP3 and AMP6 are bright, the AMP1 is analytical, the AMP5 is smooth and the AMP4 is the best overall. Thanks.AMP1 has the most analytical sound. AMP3 and AMP6 have a lot of similarities, both are brighter tuned amps. AMP5 is the smoothest, yet still quite resolving with an excellent dynamics. AMP4 is still my favorite with the best technical performance. Regarding faster attack, it will depend on pair up, that's purely the response and the characteristics of the drivers based on synergy with a source.
I admit I haven't played much with the filters. I prefer slow roll off on other DAPs, but maybe sharp will work better for me. Sometimes I don't really notice much difference, if any. But...I bought the Ibasso specifically because of the opportunity to try out different amp modules. Maybe something more analytical would be good for a different "flavor".Before you jump into amp-rolling, have you tried going through digital DAC filters of DX150? Not everybody hears the difference, and in your case the Katana is not the most micro-detailed or analytical to begin with (compared to K10 and Encore). But considering you just mentioned "... feel like leading notes are soft...", it sounds like you are hearing a slower attack of the notes. Filters do affect the sound in a subtle way, and can help to fine-tune the sound. See if that can make a difference. For example, with Sharp Roll-off I hear a faster attack and more sparkle, with Slow Roll-off I feel the attack is a little slower while sparkle is the same, and Super Slow Roll off has the slower attack and less air/sparkle in comparison to other filters. The effect is subtle, but noticeable to my ears (using U18t w/Horus for listening).
Regarding amp synergy and attacks, is this the case?
Say headphone x has better attack with amp 3 but less with amp 5 whereas headphone y has better attack with amp 5 but less than amp 3.
I don't own either DAPs and have only demoed the DX200.Yeah, something like that. I just tell you how I hear things, guys in Sound Science section of HF will back it up with formulas Bottom line, just because you hear a specific sound change or an improvement with one pair of headphones, from my experience I haven't found this to be consistent with all other headphones due to so many variables related to sound sig, driver type and config, technical spec of the driver, etc.
What do you hear with different ibasso amps?
I also prefer slow roll off vs fast roll off. To me, slow roll off has more accurate attacks and decays.I admit I haven't played much with the filters. I prefer slow roll off on other DAPs, but maybe sharp will work better for me. Sometimes I don't really notice much difference, if any. But...I bought the Ibasso specifically because of the opportunity to try out different amp modules. Maybe something more analytical would be good for a different "flavor".
This has piqued my interest.
Yesterday mid morning i used the DX150 for a short time with FLAC and the xDSD as I was doing some tests.
Now as you look at the above picture you may be forgiven for saying ‘shaddup expat! Thats a decent nine hours of play there ya numbnuts!’
But I only used it for less than an hour in the morning.
Usually I am quite lucky with daps etc. so my inner Poirot got his little grey cells going.
Earlier there was another picture posted of battery drain also. Which was the catalyst to my investigation (ongoing).
In their photo it had Android as the main culprit.
In mine it had miscellaneous.
Two differences, not sure what they could mean.
So I charged it up to 100% last night whilst watching the latest episode of Westworld. Then unplugged it and went to sleep. Leaving it in rest mode, not turned off.
Above was after about 7 hours I think.
The main thing I did was close all the open windows before letting it sit in a rest mode.
(A good idea with iphones too).
*usually on DX200 i use non android Mango so less background activity.
Anyway I will check it again when I return home and post the next installment.
I love a good mystery, and men generally like to find solutions to problems.
*EDIT: I was also tempted to install Lurkers FW but am a bit worried about following the steps.
So 5% in 9 hours? About 12% drop per day thenOk home now some eight hours (?) later
Not turned off. Just sleep/standby mode.
Nothing open etc ....maybe I left the settings open.
