iBasso DX150. Dual dacs and interchangeable AMPs. **NEW Firmware that supports AMP9! ** New FIRMWARE 1.05 Dec 30.
post-15181534
Post #2,746 of 2,956
gr8soundz
Hi all :)
Any way to install Mango player from DX220 to Android 6.1 DX150FirmwareV2.11.293-L0 ?
Mango OS is great. But also would like to enjoy Mango player while in Android mode.
Thanks!
For now, only way to get DX220 Mango player on DX150 is via Fidelizer rom V1.12.149.
Would be nice to have both options but you'll need to get a DX220 for that at the moment. I also thought I'd prefer Mango OS over the Android app but I like the PMEQ in DX220's player.
post-15190620
Post #2,747 of 2,956
Acher
Czechia
Czechia
Hi,
I need to ask for an advice.
I want to order Miter case for my iBasso DX150. Does it fit on DX150 with AMP8? I mean if there is, downside, enough of cut out space for access to larger 4.4mm jack…
Thank you :)
post-15192851
Post #2,748 of 2,956
Acher
Czechia
Czechia
I was impatient, so I have already ordered the Mitter DX150 case and hope it will fits right to my DX158 :ksc75smile:
post-15194499
Post #2,749 of 2,956
TjPhysicist
Toronto, Ontario, Canada
BTw guys, anyone tried the new amazon HD service? Anyone know how/why Amazon App reports maximum ability of 44.1 only? I've using @Lurker0 s rom, IIRC only NATIVE apps/non streaming support bitperfect right? is there any way to change that?
post-15194726
Post #2,750 of 2,956
yannis
Somewhere over the Rainbow
Unfortunately, you are right.
Android 8 is required for Mango player 2.1.4 from Fidelizer rom.
So I have few options :)
Change firmware from time to time
Learn to code Android
Save money for DX220
Lurker and WindowsX are probably busy with other projects...
post-15212042
Post #2,751 of 2,956
equalspeace
Can anyone tell which of the amp modules from iBasso has the least amount of noise? Also, if iBasso made a lower powered amp module that was dead quiet for sensitive iems, I'd be all over it.
Reactions: buonassi
post-15214306
Post #2,753 of 2,956
yannis
I`m using Fidelizer Purist ROM and MangoPlayer.
I have updated player from latest DX220 firmware.
Version on Fidelizer is 2.1.4 and latest version is 2.1.9.
Brown background.
Seems faster :)
Here is link for APK files if intrested:
https://filebin.net/21l1catzukcok47x
And here is the version from DX160
https://filebin.net/b3kvwpa78cdthyw6
Same 2.1.9 version but with blue background like in
Reactions: Arghavan
post-15214823
Post #2,754 of 2,956
buonassi
Peoria, IL
Peoria, IL
Amp7 is pretty low noise compared to amp6. However, that's all I can confirm first hand. @twister6 did a review of all the amps with the dx150 on his website so you can reference that for more info. He does mention hiss relative levels between modules.
Reactions: equalspeace
post-15215879
Post #2,755 of 2,956
Arghavan
I'm currently using AMP7 with Campfire Audio Solaris, which is a pretty sensitive IEM. There is some hiss when no music is playing but it fades out as soon as you play one. Still not as black background as AK players or using iEMatch settings on iFi devices though.
AMP7 is one of the quieter amps from iBasso that you can buy today, less hiss than AMP6, AMP8 and AMP9.
Reactions: buonassi
post-15215905
Post #2,756 of 2,956
ejong7
Kuala Lumpur, Malaysia
@Lurker0 Any tips on using your firmware tool for Win10? Notice that it doesn't show Unknown Device but show as RockChip Device instead. So do I just skip the driver step?
Can't seem to get any of the ports go blue in the firmware tool.
post-15215985
Post #2,757 of 2,956
Lurker0
Moscow, Russia
Moscow, Russia
If you never installed drivers from DriverAssistant, just run it once to install.
post-15232039
Post #2,758 of 2,956
yannis
post-15232210
Post #2,760 of 2,956
javre76
Apart from the new UI for Mango, any other improvement? Pretty content with my base FW and Lurker’s add-in.
