Is there a way to get Google services to work on oreo? After flashing the purist rom, loving the sound and new ui, but i kinda want to have YouTube in my player tho.
I know @Lurker0 probably off making optimized firmwares for the DX220 right now but can anyone share experience/comment on v2.11.293 stability on the DX150? I'm still on v2.10.xxx (early) but have recently been experiencing some problems with streaming services (I assume it's just getting old).
You can email me at paul@ibasso.com unless you already have. Sorry, I get many emails and don't remember everyone and feel bad about that.
You have tried different USB C cables and chargers. You have downloaded the Batch Tool with a .img firmware or the newer Android Tool with the associated .img firmware? You need the USB/DAC driver from our site loaded onto your PC.
DId you forget to run disable verity script before flashing Purist ROM? You can flash official factory image > OTA 1.03 > Disable verity > Purist to make it work with DX220 ported ROM and you can put addon on top.
All iBasso Purist ROMs have factory image to restore from failed attempts so you can always use AndroidTool to flash this ROM image and fix your iBasso DX150 device. You then can try flashing Purist again and make sure to follow the instructions properly this time.
When I connect my dx150 to my amp through line out, what settings should I have set on my player (DX150)? I always thought that when you use line out to amp the volume locks on the device (DX150) and the master volume is the external device (amp)? Or am I thinking wrong, because i still have control of the dx150s volume control. I've been using the lurker hiby player with usb audio switched on. Is there a better way to go about this with the right settings if I am missing something? Thanks
No I don't think so as I followed the instructions on the website to do so. But now I need to get my device at least start up first... Paul is helping me with this issue currently
You can flash this one to get device booting up and then update to 1.0.3 OTA. I'm sorry for confusing instructions I provided before and now I've updated it to be more clear now. If there's anything I can assist you with, please let me know.
Thank you for the quick reply! So my problem occurs when I try to get lurker addon alongside with your purist rom, note that purist rom was working just fine before hand, i believe I had made a mistake during the addon flashing part. As I'm not with my device right now, i shell keep you up to date with the situation. Again thanks for the help from you and Paul
But how do I flash the original rom given that the file is a zip folder but not a img file? As my current device is stuck in loader status with nothing displaying on the screen.
