iBasso DX150. Dual dacs and interchangeable AMPs. **NEW Firmware that supports AMP9! ** New FIRMWARE 1.05 Dec 30.
Apr 24, 2018 at 12:05 PM Post #586 of 3,129
Is there any way to reset player. Mine was booting up and the screen went blank. Now it will not come back on. I hold down power button but nothing happens.
Mine died also two days ago. I sent it back
Apr 24, 2018 at 12:15 PM Post #588 of 3,129
It's just a modified phone, I was upgrading to new firmware and it stopped. There should be a way to reset it. Doesn't even show charge when I plug it in to charger now.
No such thing as a hardware reset from a pinhole or similar, only from the android settings screen, which is obviously not an option if the screen doesn't work. iBasso support was not able to help either, that's why I decided to send it back. I believe the issue is the battery, not the electronics.
Apr 25, 2018 at 9:08 AM Post #589 of 3,129
Is it normal that it is kind of hard to get a TOSlink mini into the top SPDIF port? I have a couple of toslink mini cables I've used on my macbook pro (that has a dual headphone/optical port) and it works great. I tried it on my DX150 and it works fine there too... once I can actually get it to go in. It gets stuck about 2/3 of the way in, until I keep trying and get lucky and hit some perfect angle.
The included 3.5mm to digital coax cable fits just fine.
There is a spring loaded contact that you are hitting. Some plugs have a more gentle angle and go past this point easier as the contact is pushed on and some have a steeper angle and it takes more pressure to get past this point.
Solution for others who may be having this problem with using a mini TOSLINK cable in their DX150 SPDIF port:
I ordered cables from another brand, and they also took several tries to get them inserted. Finally I realized that a trick that works well for me is to rotate the cable while applying normal light pressure until it just goes in.
Then I went back and tried the old brand, and found this works there too.
Apr 25, 2018 at 9:51 AM Post #590 of 3,129
MIne comes on with a faint light grey screen but cannot access USB ports to flash. Paul tried to help but nothing is working. Looks as if I need to send mine back also.
Apr 25, 2018 at 11:27 AM Post #591 of 3,129
Just got the DX150; have just started burning it in.
(very) initial impressions (DX150+AMP6 vs DX200+AMP3 with balanced CB12 cable and IT03 IEM's):
Really enjoyable low end boost that doesn't bleed at all into the mids.
Musical and dynamic, with a spacious and clear sound.
There seems something slightly more TOTL and reference sounding in the DX200+AMP3 combo, but the DX150 is pretty close to that, and with qualities that promise a LOT of enjoyment to come :)
Apr 26, 2018 at 2:00 AM Post #592 of 3,129
I will buy Ibasso Dx150 soon i like it
This is my only concern that it not come with Google play store app.
I need to use Poweramp and Neutron and for this Google play store
Ibasso Dx150 dont come with Google play store which is sad
it should have come with it beging android.
But this i can do i can install Both poweramp and Neutron as APK manualy
download APK to Pc and transfer APK to dx150 and install manualy
But here is my concern I have already purchased Neutron and Poweramp
and many paid themes for Poweramp (They look lovely)
so when i download poweramp and neutron on new Audio devices
i dont have to purchase again it can be used on all audio devices
by logging into to my google acount where i purchased it from
and use same google play user.
But this is if i use Google play store
But installing Poweramp manually APK
will Poweramp verify with Google that i have already purchased it before
and redownload it on dx150 for free?
And what about Poweramp themes i purchased can i download them again for free.
And how do i install Poweramp paid themes without Google play store?
With Google play store there was no problem redownload poweramp and themes
for free when i already purchase them
but how do i do this manually by APK.
I hope i dont have to purchase neutron, poweramp and all poweramp themes again (which is a lot)
how can i redownload all themes on Poweramp without google play
i bought a lot of themes i want to be able to use it on poweramp on ibasso dx150
without purchasing them again?
thanks
I know that Lurker0 probaly make a custom firmware soon
with google play store but i mean until then what i can do
to use poweramp + paid themes on ibasso dx150
Apr 26, 2018 at 2:03 AM Post #593 of 3,129
So i read i can install Both poweramp and Neutron as APK manualy
will Poweramp verify with Google that i have purchased it
And how to i install Poweramp paid themes without Google play store?
thanks
You can use this rom first for google playstore support.
http://www.fidelizer-audio.com/tag/dx150/
Apr 26, 2018 at 5:31 AM Post #594 of 3,129
thanks
This poem was a reasonable effort.
I could sense the emotion and the tangible sense of anguish and loss, juxtaposed by hope for future restoration.
The structure and meter could be improved upon; however overall this is a promising effort.
Keep up the good work.
7/10.
:wink:
Apr 26, 2018 at 5:34 AM Post #595 of 3,129
7/10.
:wink:
Didn't realise you were a poetry teacher Marcus!
Apr 26, 2018 at 5:45 AM Post #596 of 3,129
Apr 26, 2018 at 5:47 AM Post #597 of 3,129
Apr 26, 2018 at 7:21 AM Post #598 of 3,129
Well, with help from Paul@iBasso and his software team, with a little manipulation and patience on my part, my DX150 has resurrected from the dead and will not be going back to China.Hats of to Ibasso!
Apr 26, 2018 at 7:28 AM Post #599 of 3,129
If I understand correctly, your DX150 was not totally dead like mine was, in the sense that some flickering response from the screen was still there, right?
