- Oct 6, 2013
That penon adapter is so sexy.
and crazy enough, it actually widens the soundstage
Just got these PlusSound cables from Massdrop delivered 2 months before the advertised date (OCT29). Got them mostly to tighten up my on-the-go rig
DX150 + AMP8 >> 4' PlusSound X6 Copper >> TH900mod
Niiice, do you find the cans is properly driven?
I find Beyond Creation, Conquering Dystopia, Vai, Pantera, Plini etc sounds good already with amp6. It is also dependong on your cans.Hi guys I'm interested in this player, but went to try it and this player sound more focus on the vocals or boosted a bit, does the Amp changes the sound? I mainly listen to rock and metal
Look for a USB-C charger that supports PD 2.0.Hello guys, im looking for charger for this player. If i will buy charger with quick charge 3.0 it will be work with our player on QC 2.0 if this player is not on qualcomm chipset(our on RK3368)? Is this charger is good Grand-X CH-550B?
Hi, Matt.Hi all, with new firmware 293, I have encountered memory crash while pull down menu for volume down. And playing CUE at the end of the song. it should stop but mine encountered loop that it stop and play and can't do anything to stop it, only shut down will do. And I feel that the filter not working. Reversed back to 275, while playing CUE list no more relay (strange) and it stop at end of the song. Volume down working from pull down menu. And I feel the filter can't work too. Using 275 now but can't play with other earphones because filter not working. This is what I encountered, for other not affected, blessings.
Forget to inform, all done with hard reset.
Regards.
Matt
Hi, Matt.
See my issues with this latest FW a few posts back #1509. I too have rolled back to stock FW2.10.275. I've posted comments regarding this on iBasso's Facebook page, Messenger and gotten a few replies from Paul. (His two suggestions: do a Factory Reset and Scan Internal / SD Card separately.) This didn't help at all-and I went through the ENTIRE update process from start-to-finish TWICE!
