iBasso DX150. Dual dacs and interchangeable AMPs. **NEW Firmware that supports AMP9! ** New FIRMWARE 1.05 Dec 30.
- Thread starter Paul - iBasso
Uk folks, does anyone have advanced mp3 voucher code they used recently?. Looking to get the dx150 from them.
try amp500 or amp300
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
Accepts it but doesn't knock anything off, best is the standard ten percent.
Can you give me the code for the 10%Accepts it but doesn't knock anything off, best is the standard ten percent.
Dash
- Aug 10, 2005
I am having trouble downloading the new firmware. Every file from Ibasso's site has been empty or corrupted. The DX150 sits forever when attempting to update via Wi-Fi and eventually says check your network.
Any advice?
Any advice?
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
If you go on the site, it should pop up after a few minutes. Changes each time.
Lunatics
- Dec 7, 2015
I know Lurker posted on here that it works, but when I go to github for the new firmware, this is posted in the description of it "Note: The primary USB Audio function does not work as it should: USB DAC appears in the system and is recognized by applications, but playback produces no sound. I hope it will be fixed in future firmware builds. You can still use its System settings." which is why I asked my question a day or two ago. Am I looking at the wrong place for his firmware or something, just don't know why it specially says that in the description.
Hawaiibadboy
BANNED
Lurkers new FW feels very very fast.
Really good work.
Love this thing and that FW he did is excellent
Really good work.
mrmoto050
iBasso does not upgrade via wifi, you have to download zip file and unzip.I am having trouble downloading the new firmware. Every file from Ibasso's site has been empty or corrupted. The DX150 sits forever when attempting to update via Wi-Fi and eventually says check your network.
Any advice?
Really good work.
There's a new one? Great. I'll upgrade after I get my Gaming/Multimedia PC.
gazzington
To use lurker updates, do you install in the same way. As in copy zip file in to sd card root?
no. trough the tools in the lurker siteTo use lurker updates, do you install in the same way. As in copy zip file in to sd card root?
jamato8
Listening with the latest FW with the IT04 to Santana, "Supernatural". All I can say is wow, well also, excellent bass response but the sounds even on powerful bass stays open and airy. Great stuff! Listening to "The Calling" right now.
groovyd
- Jun 29, 2012
Looking for a new DAP to replace my DX90 because the DX90 takes like 5 min to read my SanDisk 400gb microSD. Can this handle 400gb cards without UI lag? That is my biggest concern in getting anything new. When I say lag I mean for example browsing into albums or artists or all music it takes the DX90 literally minutes each time even after rescanning the library etc.
Wrote their support this...
I have a DX90 but trying to use it with my SanDisk 400gb uSD is basically useless since it takes literally over a minute to go into 'all music' and select artists or albums even after it finished scanning the library which took 30+ minutes.
My highest priority is finding a DAP that properly handles 400gb cards and remains instantly responsive throughout the entire UI. Is that something the DX150 can handle quickly or will I throw it across the room?
Dobrescu George
Reviewer: AudiophileHeaven
iBasso DX150 and Simphonio Dragon2+
The pairing is quite good! For a 300 USD Earbud, the Dragon2+ is a love for the ears and it totally pairs well with DX150
Total: 6 (members: 0, guests: 6)
