Regarding plug the dx100, try to press the volume+ and power. Basically you want to go a mode not usb storage ( similar to I devices) when updating the firmware
If it doesn't work - the tool doesn't sees the dx100 you need to install the driver
For the driver installation part, unplug the dx100 from PC, turn off the dx100, then press and hold volume + and power. Then plug the dx100 using usb (still holding the vol+ & power and release after 5sec. the dX100 should turn on.
Does the PC sees a new device? Unknown device . if you see that you need to install the rockchip driver.
Thanks for continued patience mate
OK , so when i hold power and vol+ ( i have tool gui launched and dx100 plugged into laptop)
nothing happens on either end , no dx100 response , nor tool response
UGH for some reason now , i cant even boot dx100 .No response , i even plugged into wall outlet and no life in it .So i had to do a reset via vol+ and reset .
But this way im faced with a turn on usb storage message ,and no tool response.i turn on usb storage , still not recognized
When i
" For the driver installation part, unplug the dx100 from PC, turn off the dx100, then press and hold volume + and power. Then plug the dx100 using usb (still holding the vol+ & power and release after 5sec. the dX100 should turn on."
My dx100 greets me with a little android man , above his head is a triangle with an exclamation mark in the triange , no response from tool , not seen in device manager ( tho no matter what there is always an unknown device under other devices ,this is normal for my laptop,dx100 or not .
i sat here looking at it for maybe 15 minutes hoping fo smething good , nowt , so i did a vol+ and reset button
Back to nowt again .
Then i tried above again , and this seemed to kill device again , had to do a vol+reset again to see life.
PS , when i say its not recognized , i mean in device manager , i can see and access the dap in windows drives Ie C , D , etc i can add o remove music etc
Im at wits end here lol
PS in case i do figure this part out , i d still be lost on next step . So using the dx100 tool gui what is it im trying to install , one of the Rock sub drivers in this path DX100 tool\driver\Rockusb\x86\xp
Here i see 3 choices rockusb.cat , rockusb.inf , rockusb.sys
Is it one of these above ? Or is it my firmware Ie DX100+Firmware+V1.4.2+Apr+24th,+2013
I always thought to install firmware updates as above , i dropped the img on the root of dap and rebooted , ive done that many successful times
R U face palming yet ? LOL
Cheers
