Sorensiim
- Dec 11, 2008
If you guys find yourself looking for a closed circumaural, you can do far, far worse than this... Just got them today
how do you find them with dx100?
I see, they are a bit inefficient for 32ohms I think you can pick up a replacement headband http://www.amazon.com/Replacement-Leatherette-Universal-Sennheiser-Beyerdynamic/dp/B00862522A/ This is more comfortable than the stock band
Going back to the DX100, it can really provide tight bass to the supposedly boomy DT770 A/E
Hi guys, could anyone recommend a portable charger that can be used with the DX100. any response would really be appreciated. thanks.
I think the Energizers XP series work with the DX100......
I am using the Energizer XP series (8000mah) with my DX100, and yes it can charge the DX100, however, there is only a very short adaptor (instead of long wire) that comes with the battery which could connect the DX100 with the battery, which sometimes may become quite inconvenient for use....
By short adapter, u mean it doesn't have wire connected to the adapter? instead just the adapter without the wire?
Yes just the adaptor without wire.
I used to pair the W4R with DX100, using silver dragon v1, and changed to ES5 with TWag v2 later until now. For both setup, I don't really find the DX100 sound "veil". Instead I found that both of them made the DX100 sound more dynamic.
