Saraugie
Formerly known as Saraguie
Removed by me....wrong area
Hi folks
Pardon this post as I am writing this while laid out in bed.
Thanks for the info. The code points to two different lines for music time location. Oneis the "scrub" bar and the other is the button press. The iissue is that this "time-lapse" is based as the file is read on power on.
Eq- it is a very simple 2 dimension array which is stored in db file. Why they just don't leave the array in RAM for faster read is beyond me. each unique array, is tied to a central frequency and assigned a q value. I will have to test something out. The eq can be made to have more channels no problems (just add more arrays). In other words change it from a 7 channel parametric eq to say a 1/15 octave or 1/30 octave eq. The issue will be to draw them correctly on the real estate that it has. This of course is lower priority than the file search pop issue.
I think it would be nice though and probably would speed this along. Remember the Hifiman 901 is around the corner... Hopefully they reading this because I am on the fence about selling my unit and getting a 901 depending on how things pan out.
You know you wanna join the party .
After listening to some music last night , battery still
near 70% plus , the device wont power off
The screen has stopped responding . I have been trying
many times through the night
DX100 still recognizes media i plug into micro usb etc , but
screen wont respond . I tried holding power button for an extended
time as my other android device will shut down that way if the
screen stops responding
What can i do here to fix this ?
i see a reset pinhole on the side of unit . Will this erase all internal data tho ? And send me way back
to original firmware .
Cheers
Roze......which version of the firmware are you using now?
Cheers
It doesn't erase data. Just reset it and you should be fine.
Any idea why this happened?
Somewhere in the software but why exactly, I don't know.
before I get neck deep in the coding.
I keep seeing like the preffered player is the one in 1.1.7 over 1.2.3?
is this correct? I have been focused on 1.2.3 so far but can go tro 1.1.7.
with that said,
was there anything that 1.1.6 did that 1.1.7 broke?
