IBasso DC-Elite . . . The no compromise DAC/AMP with a true Stepped Attenuator
Dec 28, 2024 at 8:53 AM Post #1,157 of 1,358
A picture for Elite users that were interested in the Fiio MagClip.
Nice. What are you using as a right angle adaptor? Does it need to be specific or any old one off Amazon?
I noticed you changed the band…. Nice ;)
Dec 28, 2024 at 11:50 AM Post #1,160 of 1,358
Have app for iOS ?
Please ehelp
The app is nice to have, but other than changing the filter from d1 to d2, there’s not a ton of functionality you are missing out on with the DC Elite. I have an old Android tablet that I use when I feel like changing the settings, which hasn’t been often because it is pretty great out of the box.
Dec 28, 2024 at 1:23 PM Post #1,161 of 1,358
Thanks friend , ie900 sounds amazing with them
Dec 28, 2024 at 4:02 PM Post #1,162 of 1,358
Hi all - I'm trying to connect my DC-Elite to my xduoo XD05T via coaxial/optical and I'm using a standard 3.5 mm cable on both ends. I know the DC-Elite needs to light white but it's showing no signal when I set it to receive on the amp. Do I need a different kind of 3.5mm cable?
Thanks!
Dec 28, 2024 at 4:04 PM Post #1,163 of 1,358
I'm reading around. Do I have to use a 4-pole 3.5mm?
Dec 28, 2024 at 4:09 PM Post #1,164 of 1,358
Dec 28, 2024 at 4:19 PM Post #1,165 of 1,358
Dec 29, 2024 at 12:35 AM Post #1,166 of 1,358
Dec 29, 2024 at 8:08 PM Post #1,167 of 1,358
Hi, can DC-Elite fit the Lepic Dac Pocket Magsafe? Have anyone try this?
Their new "large" sku has the Elite in one of its product photos!
https://amzn.to/3DuJdlg
I just ordered one yesterday to try it out. Should have it in a couple of days.
Was delivered today. Seems well built. Magnet strength is good. Elastic and stitching seems durable. Adds minimal bulk to a setup and the end result is more pleasing then options that have visible bands. The DC Elite is on the maximum of what it will fit, but it fits as they depicted it. Took a bit of stretching from one side while pushing it in from the other. Ends with it held in there very securely. I don’t think it’s one to use if you want to take it in and out all the time, but if you want to leave it in the holder then I think it will work out well. Also the extra loop to either hold your USB cable or to route your headphone cable is nifty.
Dec 29, 2024 at 8:57 PM Post #1,168 of 1,358
And let’s not forget the times you need a bit more power…
Add a MagSafe ring sticker to the back of a MagSafe battery that has a USB A port.
Dec 29, 2024 at 9:21 PM Post #1,169 of 1,358
Received mine today also and I can concur with all of your statements exactly. Thanks for the suggestion on it. Have on order the fiio MagSafe band attachment but I think this is going to be a cleaner setup. I have a jar full of usb right, left, and center angled adapters so I was able to make it fit well enough for now. Which right angle cable are you using, the ddhifi?
Dec 29, 2024 at 10:23 PM Post #1,170 of 1,358
Yessir, it’s one of their older ones which are a bit tricky to find. Looks like Audio46 still has some:
https://audio46.com/products/dd-ddhifi-tc05-2021-type-c-to-type-c-usb-otg-cable
I also noticed they have a newer version as well:
https://audio46.com/products/dd-ddhifi-tc09l-usb-c-to-usb-c-otg-cable
