iBasso D10. .UPDATES 1st page, with Current Opamp Choices by HiFlight . . . images page 1, 12, 13, 14, 15, 21, 71
Jan 4, 2010 at 8:39 PM Post #3,751 of 4,153
I finish modding my D10 as well some time back, I guess we all stop after completing OP_AMP rolling. I am using it more as a experimental test bed now. I just completed a hyper modded D4 for a friend. added a 5V to 12V DC converter using AD797 and BUF634 as well, waiting for AD8610BRZ before finalizing. It is much better than my D10, smaller in size, and so far can drive any headphone I throw at it.
For the resistor mod I am thinking along the line of reducing resistor noise since we are using OPA211 which have a noise floor of 1.1nV/Hz, The 2K resistors noise is already a few times that. I am thinking of reducing it to maybe 600ohm to see if it made a difference.
Originally Posted by qusp /img/forum/go_quote.gif
i'm assuming you have simply drawn traces and basically 'copied' the A input for the B input on the adapter for single BUF634 yes? certainly looks like that and I cant think of a reason it wouldnt work as that is what we are doing albeit with another chip if 4 BUF634 are used.
@ Theory_87
yes these pics above were a mod for a fellow head-fier, mine is finished with too and I have even changed the feedback resistors to TX2575
but i'm in the same boat as you, my appetite is for modding FiQuest now, I have taken the D10 about as far as she can go, she sounds brilliant, but cannot quite compare with the combination of iRiver->D10->FiQuest. this combo is simply sublime and will continue to get batter as I take it to new heights. I am still glad I have my D10 in this state though in case I must go down the shops in a hurry with only my shorts and/or need longer battery for a long trip. in this case I do not miss too much, but I do miss something huge and authoritative power
Jan 5, 2010 at 3:30 AM Post #3,752 of 4,153
PCX nolonger have them, you might be able to get them at percy audio, search the threads here for recommendations. I have some left but i'm afraid i'm not letting go of them
Darn, are there any canadian sellers for bg's? or are there any other recommendations for bypass caps?
Jan 5, 2010 at 3:32 AM Post #3,753 of 4,153
you might try reading the last couple of pages; I have already covered that i'm not 100% sure BG are the best for bypass caps anyway
Jan 5, 2010 at 3:38 AM Post #3,754 of 4,153
ok, thanks qusp
Jan 7, 2010 at 6:17 PM Post #3,756 of 4,153
Parts Connexion, Burlington, Ontario
I got BGs for my D10 there, and they have more in stock.
Jan 7, 2010 at 8:56 PM Post #3,757 of 4,153
PCX has 440's and 220's but I'm looking for .1 uf and 22 uf BG's.
Jan 8, 2010 at 9:52 AM Post #3,758 of 4,153
well I'm interested if OPA2111 can be beat. IMO its better than any other I have tried in the D10. with AD8656 buffers. the bass control is AWESOME and soundstage is amazing.
I've installed the OPA2111 in my D10 with AD8656 buffers too.
Sounds very good, except for a slight background hissing that's really annoying.
Anyone has the same issue? All my other opamps produce a very clean sound... Are there faulty OPA2111KPs?
Jan 8, 2010 at 11:02 AM Post #3,759 of 4,153
I recommend catching up on more recent recommendations for sensitive IEMs, we know much more about this dacx/amp now. I cant remember if I even still have the OPA2111 will have to have a look
Jan 8, 2010 at 1:18 PM Post #3,760 of 4,153
Hi, I just received my D10 and quickly (at work) tried it with Klipsch Custom 3 IEMs via USB and whoaaa !
I'm far from being an audiophile, but my tracks are far more enjoyable with this setup than with my iTouch+FiiO E5 or E1
I like this DAC so much that I just ordered an iRiver iHP140 from Ebay
Is replacing its 40GB HDD with a compact flash or SDHC very difficult ?
I mean if I open it, will I be able to reassemble it easily ?
Jan 8, 2010 at 4:13 PM Post #3,761 of 4,153
It's not difficult at all, however you should start reading up on rockbox as you'll need that to install a solid state card.
Jan 8, 2010 at 4:35 PM Post #3,762 of 4,153
No problem, in fact very few of my electronic gadgets runs on their original firmware
Jan 8, 2010 at 7:47 PM Post #3,763 of 4,153
Jan 9, 2010 at 10:57 AM Post #3,765 of 4,153
hello
I asked what is the best combination for the opamp Ultrasone Edition 9?
I thought about ADA4841 2 xAD8656. ADA4841 can better turn to another only on what is best?
sorry for my english
cheers
