I try to remove the volume know, but it sits quite tight. There is no screw visible, has someone removed it before? I don't want to break anything...
Ibasso 1 bit Discrete portable DAC with Resistors Array D16
- Thread starter Whitigir
Death_Block
I personally like the volume knob tension. Feels premium.
Death_Block
The smaller volume knob on the other hand feels terrible, mine wiggles, is that normal?
Not sure how to upload a video of the wiggle.
That's not what I meant. I try to remove it (pull it out), and it sticks like hell, and I don't want to break it. The operation is absolutely fine.I personally like the volume knob tension. Feels premium.
Death_Block
Ah. I've never tried to remove it and can't think of a reason I'd want to so sorry, can't help
Nightshifter
Why do you want to remove it? I don't think that it is possible....
Someone put a mark on it, as a the original is hard to see. But unfortunately at the wrong position. No big deal, but doesn't look 100% perfect.
Usually these knobs can easily be pulled off, but this one seems to be glued or whatever.
Death_Block
Still wondering on the smaller volume wiggle issue
Golyatx
that is how it is, nothing can be doneStill wondering on the smaller volume wiggle issue
Nightshifter
That's by design.
Death_Block
Fair enough. But why? Am I not seeing something obvious?
THX for sharing
Torben
The D16 has 15,2 Ah at 3,8 V, the LHY has 9,8Ah at 5V. So the LHY has approx. 10 Wh less than the D16.How many hours do you get with that? What do you power it with other than the D16?
Golyatx
its just a 1,5k$ dacampFair enough. But why? Am I not seeing something obvious?
What is your suggestion than?The D16 has 15,2 Ah at 3,8 V, the LHY has 9,8Ah at 5V. So the LHY has approx. 10 Wh less than the D16.
THX
Torben
