Ibasso 1 bit Discrete portable DAC with Resistors Array D16
Nov 5, 2024 at 1:34 AM Post #1,126 of 1,678
Tried again, on PC, everything is fine until I plug in the USB cable for iBasso charging
PC, tablet, mobile phone, iPad, same story.
But this is not happening with iBasso and Violectric V222
Now, who's the culprit? IBasso or iFi iCAN Pro Studio?
I forgot to mention something : When I use the PC, i connect the iBasso D16 to PC, from the iBasso USB C ( DAC). to PC - USB A. Everything ist fine and no noises.
As soon as I plug out the USB A from PC, noises.
That doesn't bother me much. Because I don't want to plug out the USB A from PC, while using it.
But, when I use the mobile phone or tablet, I connect the iBasso USB C to mobile phone / tablet / USB C
Without the charger connected to iBasso, is silent
As soon as I plug in the USB cable for powering iBasso, noises
You may also what to try using a small external battery back and see how that works! Good news: it will be lifted from ground. Bad news: depending on battery chemistry and regulator, may or may not provide the best DC power. Very battery dependent IME and I haven't found a great small, mobile battery pack. I use this, which is technically portable, but not really... I use this thing to power all my desktop electronics and unplug it from the wall when listening to music, and plug it back in to charge. I think the battery is LiFEPO4, so low output impedance 12 V battery driving the regulators that provide 5V DC via the USB out.
Nov 5, 2024 at 2:34 AM Post #1,127 of 1,678
This can be used:
https://www.audiophonics.fr/en/hifi...ar-power-supply-on-battery-5v-2a-p-18477.html
Just unplug it from main when listen to music
Torben
Nov 5, 2024 at 3:34 AM Post #1,128 of 1,678
Nov 5, 2024 at 3:38 AM Post #1,129 of 1,678
How many hours do you get with that? What do you power it with other than the D16?
I don`t use the LHY with my D16, I use it with my FMC.
With my D16 I use this:
Torben
Nov 5, 2024 at 3:59 AM Post #1,131 of 1,678
Probably flat from listening too much :)
Nov 5, 2024 at 4:37 AM Post #1,132 of 1,678
Torben
Hi Torben
Looking at your picture - are you using upscaling software like Audirvana or HQPLAYER?
Nov 5, 2024 at 7:23 PM Post #1,135 of 1,678
Hi @FooFighter
I use Roon:
Torben
Hi @TRHH - I'm an upsampler as well and am curious about this DAC!
What are your impressions of the D16 with upsampling? I usually do PCM upsampling, but may also want a platform for DSD upsampling... have you dabbled with the latter?
Would love any of your perspectives.
Nov 5, 2024 at 11:01 PM Post #1,136 of 1,678
Hi @taipan254
I use "max sample rate (PCM) conversion" in Roon on the different systems that I have. I do have some DSD albums, but don't do any upsampling with them.
The D16 handles everything just super - very happy with the device.
This is my headphone setup:
Torben
Nov 6, 2024 at 2:40 AM Post #1,137 of 1,678
How does the composer sound with the D16?
Nov 6, 2024 at 3:00 AM Post #1,138 of 1,678
Very snug, excellent fit. Not even wiggle room
Nov 6, 2024 at 3:18 AM Post #1,140 of 1,678
