GreenBow
- Feb 6, 2015
Studios use 24-bit (and higher) resolution for computer processing capabilities when producing music. It (arguably) has benefits in that respect, but zero benefits in terms of simple audio playback. As I have clearly explained, 24-bit yields no extra frequencies or dynamic range that is audible to human ears. All the frequencies and dynamic range that you can ever hear are already covered with lossless 16-bit / 44.1 kHz files. I also offered to prove this to you by showing you how to conduct a proper listening test, so you can hear with your own ears that the two resolutions sound exactly the same when you isolate the variables to ensure that you are not merely listening to two different masters of a recording. There is no doubt that hi-res files can be closer to the original in terms of data, but this is irrelevant because the differences are inaudible. Same goes for 256 kbps AAC. No one has ever been able to pass a proper test between 256 kbps AAC and lossless, because lossy audio of sufficiently high bit rate is audibly transparent. Human ears can't tell the difference, and that's all that matters.
You see here we go again. That, quote,
"Studios use 24-bit (and higher) resolution for computer processing capabilities when producing music.",
doesn't even make sense. It comes across as you making something up to counter my position that studios record in high res.
Neither have you explained why higher res audio doesn't work, as you claimed here. You simply stated that it doesn't, and told me anything I said was irrelevant. Only highlighting your lack of understanding on the science. The link you supplied in favour of your position was full of science garbage.
As far as offering to prove it, I ask you one thing. If you discover you are wrong, will you have the steel to admit it. I would. I have already questioned my own logic in my last post. Yet you seem to be concocting ideas that have no reality in science.
With reference to not being able to detect 256kbps, I have to question completely. I buy CDs on Amazon, and they often give us free AutoRip MP3 copies. I listen to those before the CDs arrive in the post. They vary in MP3 quality. I know for a fact I can hear 220kbps vs CD quality a mile off. My latest buy is anything between 261kbps and 300kbps and I can hear the lower quality MP3 vs CD.
