Originally Posted by breadnbutter
Helter Skelter: I meant that all 19" desktop displays on the market (as far as I know) have the same non 4:3 ratio. I guess that your 1600x1200 display is bigger than 19"?
Personally I would love to get a 19" with 1400x1050, that would be the perfect size for me. 1600x1200 might be a little too small at this size?
There seems to be some confusion. Yes, pretty much every 19" desktop LCD on the market are 1280x1024, a 5:4 aspect ratio. They are using a physical 5:4 aspect ratio as well, though, so no distortion or "warping" is happening unless you stray from using the native resolution (native is 1280x1024, so displaying a standard 4:3 resolution like 1024x768, say, for a game, is going to look a bit odd. This bugs some people, others don't mind it). Same story with 17" displays. I fully agree that the existance of an "in-between" resolution like 1400x1050 on desktop displays would be most welcome, as it would actually offer a good reason to go for a 19" display over a 17".
Yes, my monitor (Dell 2001FP) is a 20.1" display. I believe that it is more or less the perfect size for the 1600x1200 resolution. Nothing looks "too small" on it. On the contrary, if I use my laptop with it's 1400x1050 display for a while and then switch over to my desktop, everything loks a bit too large for a while until my eyes adjust.
AdamWill: LCDs have come a long way. Response times of 16ms or better are perfectly fine for pretty much anything you could hope to do with the monitor, including watching movies and playing fast-paced games with lots of movement. Color reproduction, depending on the model, can be just about as good as most half-decent CRTs out there (this is not to say there arent's some nicer CRTs out there that don't excel in this regard). I'd say that unless you're doing graphics work which absolutely requires perfect color reproduction (which you're never going to get anywhere, really), there's no reason except for cost NOT to go with an LCD. Not having to put up with eye strain from staring at a CRT all day is worth the cost alone, for me.
Wodgy: I'm afraid there aren't any desktop LCDs running at 1400x1050 (yet, at least). I can recommend the Dell 2005FPW (1600x1050), which is another great bargain. As I understand, it uses the same LCD panel as the 20" Apple displays. Similar to the 2001FP (and much unlike the Apple displays), it goes on sale very frequently, often for under $600. Now, I know you want to buy locally, but let me assure you that the only things this ensures is that a) you pay entirely too much money, and b) you don't get any bad pixels out of the box (they may still develop later on). Speaking of bad pixels, Dell has a 30 day satisfaction guarantee. If in that period you find any bad pixels or other problems with your newly delivered monitor, you call them up, send it back, and they send you another. You are free to keep doing this until you get one you are satisfied with. Really, though, don't wory about it so much.
What happened with my 2001FP is that it arrived and I thouroghly inspected it for bad pixels when I got it and for a while after that. I didn't notice any, which pleased me. Currently, several months later, I have 4 pixels that have problems with them. I only ever notice them on black backgrounds and when I'm looking for them. They're so small as to be easily mistaken for a tiny speck of dust on the screen, and that's when I'm looking for them. On lighter backgrounds than almost pure black (that is, %95 of the time), they're completely invisible.
Wow, this post got long...
