Schalldampfer
- Sep 11, 2005
Has anyone had a diet-related tinnitus like I did? Is this normal? Or am I just convincing myself falsely that I don't have tinnitus?
Originally Posted by Comfy /img/forum/go_quote.gif Around 15% percent of general population have tinnitus. Around 1-2% have real problems with their tinnitus. In most cases chronic tinnitus is occasioned by a slight high frequency hearing loss - what you hear are those damaged inner ear cells producing unnecessary sounds. This, while annoying, is not dangerous. And usually the brain adapts in around a year's time. The best thing you can do is to accept it and try to cope with it. Masking it with sound is the best you can do, along with reducing stress levels. It's true that coffee, alcohol, tobacco and stress all make tinnitus worse. It's also true that it's easier to hear an annoying tinnitus in absolute silence. Even healthy students hear tinnitus when isolated in experimental conditions in absolute silence. Having your radio on at low volumes (talk shows) helps, also keeping the window open. In very severe cases, if the associated hearing loss is important too, one might benefit from the use of a specifically calibrated hearing aid. The tinnitus that accompanies high frequency hearing loss is usually high pitched, constant, like a whistling or beeping noise. Sometimes people hear more than one sound. If your tinnitus is pulsating along with your heartbeat, and especially if it's located in one ear only, you should talk to a doctor. In conclusion, a very large percentage of tinnitus is physiological, and the best treatment is to learn how to live with it. Getting too obsessed about one's own hearing and using hearing protection when unnecessary, is probably the worst thing you can do. There is a whole lot of psychosomatic aspects to tinnitus, and some mental strength is usually very helpful. ENT doctors and audiologists specifically will help you if these tricks don't work. Cheers. |
Originally Posted by Schalldämpfer /img/forum/go_quote.gif Did any of you have a cold-related tinnitus? If yes, did it go away completely when the cold went away? |
Originally Posted by fortney /img/forum/go_quote.gif El Duderino, I presume you are an ENT or Audiologist. May I ask you a question? If so... I recently listened to a headphone amp at low volume with efficient headphones and although I did not "think" at the time that the sound was distorted, the treble was somewhat irritating and it felt as if my ear canals had a burning sensation. Subsequently my tinnitus, which is of traumatic origin, is worse. My question is whether hearing damage can result from low intensity non harmonic waves >20 KHz? Obviously I am not an engineer. Thanks. F |
Originally Posted by fortney /img/forum/go_quote.gif TNX, El Duderino, for your comments. No infection and the burning sensation was only present when using the amp. A gentleman from India on another forum advised me that the op amp might be generating high frequencies. I think it was a secret message on the Sgt. Pepper album I was using. (hi,hi) F (former Urologist) |
Originally Posted by Schalldämpfer /img/forum/go_quote.gif El Duderino... could you comment a bit on cold-induced tinnitus, please? I think I have one, and the cold symptoms disappeared around yesterday, but my tinnitus remains. About how much longer do you think it'll last? And also, is one more susceptible to tinnitus when he's under the influence of colds and other viral infections? |
Originally Posted by El Duderino /img/forum/go_quote.gif Not a problem at all. A urologist...one of the happy triad (opthalmology, urology and otolaryngology...everyone else is miserable El Duderino |
