- Dec 18, 2007
Brandino, I don't think the lisa will damage the HD800, but the limitation on the power supply will only give you a couple of hours at most unless you use the separate power supply but it will be like carrying two bricks with you. I don't think you will do it for too long. I would use ALO rx, SR71a or Protector. But I would strongly encourage you to try them out first before you jump into it if you insist on the HD800. Becasue you may not like what you hear. Your problem is not with the amps, it is with your choice of headphones. There are many other good portable headphones that are good for this purposes like the JH13, JH16, UE18, ED8, ESW10jpn, hfi-780 that are very easy to drive but give wonderful enjoyment of music and may even be better than the HD600/650 line.
